getting map extent when using maxy and scale on cgi interface
{Scanned} {Scanned} {Scanned}
Thomas Chesky
thomaschesky at YAHOO.COM
Mon Dec 6 14:39:24 EST 2004
Thanks for the clarification. I give it a try.
Thomas
Siki Zoltan <siki at agt.bme.hu> wrote:
Hi Thomas,
As far as I know imgext an output parameter, mapserver fills it with
extents of actual image, mapext is the input parameter for the next
map generated. Insert [imgext] into your html template and you can see
the values.
Bye
Zoltan
On Sun, 5 Dec 2004, Thomas Chesky wrote:
> Zoltan,
> Thanks for the answer.
> imgext is an input parameter as far as I know. If I know it, then I use imgext to request the map with that particular extent. But in my case I only know the center point (geocoded address), the scale and the image width/height. These are my inputs. Mapserver calculates the extent when drawing the map. How can I ask Mapserver to return this extent (coordinates of bottom-right and top-left of the map) besides returning the rendered image?
> So my input is: center lat/lon; scale; width/height pixels of map
> Current output: 1) image
> Desired output: 1) image and 2) bottom-right/top-left coordinates
> Thomas
> Siki Zoltan wrote:
> Hi,
> Check imgext cgi variable. It holds the minx miny maxx maxy of the actual
> map image.
> Bye
> Zoltan
> On Sat, 4 Dec 2004, Thomas Chesky wrote:
> > How can I request the map extent (bounding rectangle's coordinates) of the mapreturned by MapServer via the cgi interface when using mapxy and scale params .
> > I have a cgi get string like this:
> > &mapxy=-122.244+37.47502&scale=1&mapsize=600+400
> > Mapserver returns the image (map) correctly. I would like to know what are the bottom,left and top,right coordinates of the returned map.
> > Can I do it via the cgi interface (any ascii response is good) or WFS or I have to use PHPmapscript?
> > Thanks
> > Thomas
> > Do you Yahoo!?
> > The all-new My Yahoo! What will yours do?
> __________________________________________________
> Do You Yahoo!?
> Tired of spam? Yahoo! Mail has the best spam protection around
> http://mail.yahoo.com
Do you Yahoo!?
All your favorites on one personal page Try My Yahoo!
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20041206/568c64f9/attachment.html
