transparency lost when layer is queried
Daniel Morissette
dmorissette at DMSOLUTIONS.CA
Mon Dec 6 18:57:10 EST 2004
Ryan, Adam wrote:
> Dear List,
> Has anyone experienced the loss of layer transparency when querying? I have
> the following querymap and layer:
You mean that you lose transparency in the QUERYMAP, right? The querymap
rendering has a bunch of issues, including the lack of support for
transparency. Hopefully this will be addressed in 4.4/4.6:
http://mapserver.gis.umn.edu/bugs/show_bug.cgi?id=774
In the meantime you're out of luck, the simple fix would be to avoid the
combination of querymap + transparency. It should also be possible to
use a temporary layer or custom classes in mapscript to emulate the
querymap effect with a normal map->draw() call.
Daniel Morissette dmorissette at dmsolutions.ca
DM Solutions Group http://www.dmsolutions.ca/
