[UMN_MAPSERVER-USERS] Internal Server Error
Daniele Margotti
margottid at COMUNE.LUGO.RA.IT
Tue Dec 7 05:32:47 EST 2004
Here is it:
LAYER #Elementi stradali
NAME "Elementi_stradali"
GROUP "A - Catasto delle strade"
DATA "./cat_strade/road_elements.shp"
TYPE line
STATUS on
CLASSITEM "ID_LINE"
MAXSCALE 50000
MINSCALE 0
TRANSPARENCY 100
TRANSFORM true
SYMBOLSCALE 2000
HEADER "./templates/nocsup_re_header.html"
FOOTER "./templates/nocsup_re_footer.html"
METADATA
"Oggetto" "Elementi stradali"
"Data creazione" "03/03/2004"
gix_layername "Elementi_stradali"
gix_layerfieldnames
"LAYER|ID_DATASET|ID_LINE|SPLIT|CLASS|ID_EDGE|FROMP|TOP|SOURCE|UFFICIALE
|CONVENZION|PROPRIETAR|GESTORE|AMMINISTRA|TECNICO|LUNGHEZZA|DIVISIONE|DI
REZIONE|DENOMIN|PERCORSO|"
gix_layerfieldalias
"Layer|Id_dataset|Id_line|Split|Class|Id_edge|Fromp|Top|Source|Ufficiale
|Convenzion|Proprietar|Gestore|Amministra|Tecnico|Lunghezza|Divisione|Di
rezione|Denomin|Percorso|"
wms_abstract "fiorea Elementi stradali ** Gix
Generated MapFile"
wms_title "Elementi stradali"
wms_srs "NONE"
END
CLASS
NAME 'Road elements'
TEMPLATE "./templates/nocsup_re_query.html"
STYLE
COLOR 0 0 0
SYMBOL "punto"
SIZE 4
ANTIALIAS TRUE
END
STYLE
COLOR 0 0 255
SYMBOL "punto"
SIZE 2
ANTIALIAS TRUE
END
END #CLASS
END # LAYER
As I told in another message, I can browse the map (and this layer)
until I remain out of certain extents that give me error.
Daniele
-----Messaggio originale-----
Da: Skweda O'Bomsawin [mailto:sobomsawin at kassini.com]
Inviato: lunedì 6 dicembre 2004 15.30
A: 'Daniele Margotti'; MAPSERVER-USERS at LISTS.UMN.EDU
Oggetto: RE : [UMN_MAPSERVER-USERS] Internal Server Error
Most of the time, internal server error is caused by a syntax error in
the mapfile. Can you post the Elementi_stradali layer section of your
mapfile?
Skweda O'Bomsawin
-----Message d'origine-----
De : UMN MapServer Users List [mailto:MAPSERVER-USERS at LISTS.UMN.EDU] De
la part de Daniele Margotti
Envoyé : 6 décembre 2004 07:35
À : MAPSERVER-USERS at LISTS.UMN.EDU
Objet : [UMN_MAPSERVER-USERS] Internal Server Error
Hi list,
I use CGI MapServer 4.2.3 on a RH9 with Apache 2.0.50:
<!-- MapServer version 4.2.3 OUTPUT=GIF OUTPUT=PNG OUTPUT=JPEG
OUTPUT=WBMP OUTPUT=PDF SUPPORTS=FREETYPE INPUT=EPPL7 INPUT=OGR
INPUT=GDAL INPUT=SHAPEFILE -->
All works, but I have a map that returns an "Internal Server Error" when
I try to zoom and show a certain extent with a specific layer.
I think the problem is due to the shapefile (or a part of it), but...
how can I be sure of it?
The browser only show the "Internal Server Error" page.
The Apache error log says: "[Mon Dec 06 07:13:04 2004] [error] [client
172.16.20.4] Premature end of script headers: mapserv"
I compiled MapServer with --enable-debug, set "DEBUG TRUE" in the map
section of the mapfile, and tried to use shp2img with these results:
[root at redhat cs]# /dati/geobase/bin/shp2img -m cs.map -o
/dati/daniele.png -e 2491361 4510665 2492415 4511455
[Mon Dec 6 07:24:37 2004].748031 msDrawMap(): Layer 0
(Confini_comunali), 0.040s
[Mon Dec 6 07:24:41 2004].893212 msDrawMap(): Layer 1
(Base_cartografica), 4.145s
[Mon Dec 6 07:24:41 2004].908452 msDrawMap(): Layer 2 (Edifici), 0.015s
[Mon Dec 6 07:24:41 2004].918383 msDrawMap(): Layer 3 (Aree_traffico),
0.010s
Segmentation fault
/dati/daniele.png -e 2491361 4510665 2492415 4511455 -l
Elementi_stradali
Segmentation fault
When shp2img processes the "bad" layer ('Elementi_stradali'), it exits
with a 'Segmentation fault' and without a more explicit error message.
I launched the following command (where "road_elements.shp" is the
probably bad shapefile):
[root at redhat cat_strade]# ogrinfo -al road_elements.shp -spat 2491361
It returns a 85 Kb output with apparently no detected errors.
How can I understand where the error lies?
Is there a more powerful debug tool?
Thank you,
Daniele
Incoming mail is certified Virus Free.
Checked by AVG anti-virus system (http://www.grisoft.com).
Version: 6.0.804 / Virus Database: 546 - Release Date: 2004-11-30
Outgoing mail is certified Virus Free.
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20041207/cfc91d57/attachment.html
