Shapefile field problem
Abe Gillespie
agillesp at VT.EDU
Tue Dec 7 17:19:36 EST 2004
Ok, you've proven to me you can *force* MapServer to give you the names
of problem fields. But try this one (use the newly edited DBF file):
<html>
<body>
dl("php_mapscript.so");
$map = ms_newMapObj("/Users/abe/Sites/ms_test/test.map");
for ($i = 0; $i < $map->numlayers; $i++)
$l = $map->getLayer($i);
putBrLine($l->name.", type: ".$l->type);
// Query test.
@$l->queryByAttributes("CITY", "/foo/", MS_MULTIPLE);
putBrLine($l->getNumResults());
if ($l->data != null) // Shape files with data.
$l->open();
$s = $l->getShape(-1, 0);
$vals = $s->values;
putBrLine("field count: ".count($vals));
while ($fld = current($vals))
putBrLine(" ".key($vals));
next($vals);
foreach ($vals as $key => $val) {
printf ("%s -- %s<br>\n", $key, $val);
$s->free();
$l->close();
function putBrLine($line)
echo "$line<br>\n";
</body>
</html>
For me I get 0 as the number of results but you can clearly see the
value getting dumped out. Barring I didn't screw up the query, this is
a problem no?
Thanks as always.
-Abe
Type: application/octet-stream
Desc: not available
Url : http://lists.osgeo.org/pipermail/mapserver-users/attachments/20041207/0bce79f5/parcels2.obj
On Dec 7, 2004, at 4:30 PM, Nicol Hermann wrote:
> Hi Abe,
> i modified your script.
> Instead of 'while' i use the following 'foreach' loop.
> printf ("%s -- %s\n", $key, $val);
> This statement returns all 54 fields of your shapefile.
> HTH
> Nicol
> Am Di, den 07.12.2004 schrieb Abe Gillespie um 22:17:
>> The problem with adding a value for that attribute corrupts the test
>> case. Can you try the following PHP code and compare your results
>> with
>> mine?
>> [php]
>> <html>
>> <body>
>> $map =
>> data.
>> $l->open();
>> $vals = $s->values;
>> ".count($vals));
>> next($vals);
>> $s->free();
>> $l->close();
>> echo "$line<br>?n";
>> </body>
>> </html>
>> [output]
>> test, type: 2
>> field count: 54
>> ACAD_TEXT
>> COUNT
>> ACCOUNT_NU
>> See how there's a discrepancy between the field count and the number
>> of
>> field names that get dumped? From my experience, the field just after
>> ACCOUNT_NU has a NULL value. I see the same behavior on my Mac OS X
>> and Debian Linux installs.
>> -Abe
>> On Dec 7, 2004, at 2:15 PM, Jeff McKenna wrote:
>>> Abe,
>>> I made a tiny mapfile with your test shp, and i see labels properly
>>> in
>>> MapServer with it. I added an attribute in the "OWNERS_NAM" field
>>> and
>>> I successfully displayed it in mapserver. Am i misunderstanding your
>>> problem somehow? (mapfile below)
>>> jeff
>>> MAP
>>> NAME "field-test"
>>> STATUS ON
>>> EXTENT 1260565.500000 941362.000000 1261605.125000 942198.625000
>>> SIZE 400 300
>>> SHAPEPATH "D:/DMSG/projects/mapserver-bugs/"
>>> SYMBOLSET "../etc/symbols.sym"
>>> FONTSET "../etc/fonts.txt"
>>> IMAGETYPE gif
>>> IMAGECOLOR 255 255 255
>>> UNITS METERS
>>> WEB
>>> IMAGEPATH "/ms4w/tmp/ms_tmp/"
>>> IMAGEURL "/ms_tmp/"
>>> METADATA
>>> END
>>> END
>>> OUTPUTFORMAT
>>> NAME "gif"
>>> MIMETYPE "image/gif"
>>> DRIVER "GD/GIF"
>>> EXTENSION "gif"
>>> IMAGEMODE PC256
>>> TRANSPARENT FALSE
>>> END
>>> LAYER
>>> NAME test
>>> TYPE POLYGON
>>> STATUS ON
>>> DATA test
>>> LabelItem "OWNERS_NAM"
>>> CLASS
>>> NAME "ttt"
>>> COLOR 0 255 0
>>> LABEL
>>> COLOR 255 0 0
>>> FONT fritqat-italic
>>> TYPE truetype
>>> SIZE 8
>>> POSITION AUTO
>>> PARTIALS FALSE
>>> OUTLINECOLOR 255 255 255
>>> END
>>> END
>>> END # Layer
>>> END
>>> Abe Gillespie wrote:
>>>> I do appreciate the help, but I'm not looking for an "external to
>>>> MapServer" way of getting access to my DBF field values. I just use
>>>> my
>>>> PHP script to *reveal* problematic shapefile fields. When there is
>>>> a
>>>> problem it's unusable to MapServer! I.e.: I can't use the field for
>>>> labelling.
>>>> -Abe
>>>> On Dec 7, 2004, at 11:27 AM, Ryan, Adam wrote:
>>>>> Abe,
>>>>> Here's a routine I use to get the header information (field info)
>>>>> from
>>>>> a dbf
>>>>> file.
>>>>> // ========== iDbf_fields ==============
>>>>> // $f is a dbf file path, returns an array of field arrays
>>>>> function iDbf_fields($f){
>>>>> $h = fopen($f,"rb");
>>>>> $a =
>>>>> unpack("cversion/cyy/cmm/cdd/inumrecs/sheadsize/
>>>>> srecsize",fread($h,12));
>>>>> fread($h,20); //skip some reserved space
>>>>> for($i=0;$i<($a["headsize"]-33)/32;$i++){
>>>>> $fa = array();
>>>>> $fname = trim(fread($h,11));
>>>>> $fa["type"] = fread($h,1);
>>>>> fread($h,4);
>>>>> $fa =
>>>>> array_merge($fa,unpack("Clen/Cpre",fread($h,2)));
>>>>> fread($h,14);
>>>>> $flds[$fname] = $fa;
>>>>> fclose($h);
>>>>> return $flds;
>>>>> When I generate a result table I'll go through the array like this:
>>>>> ($so is
>>>>> the shape Object)
>>>>> foreach($flds as $fname => $fA){
>>>>> $val = $so->values[$fname];
>>>>> if ($val==null)$val=" ";
>>>>> $val = str_replace(" ","
>>>>> ",$val);
>>>>> if ($fA["type"]=="D"){$val =
>>>>> substr($val,4,2)."-".substr($val,6,2)."-".substr($val,0,4);}
>>>>> echo "<td>$val</td>";}
>>>>> Cheers to all,
>>>>> Adam
>>>>>> -----Original Message-----
>>>>>> From: Abe Gillespie [mailto:agillesp at VT.EDU]
>>>>>> Sent: Monday, December 06, 2004 5:14 PM
>>>>>> To: MAPSERVER-USERS at LISTS.UMN.EDU
>>>>>> Subject: Re: [UMN_MAPSERVER-USERS] Shapefile field problem
>>>>>> It's a regular shapefile. I think I've mostly narrowed it
>>>>>> down. It seems to me (though I may be completely off) that
>>>>>> MapServer loads the first record of the DBF in order to get
>>>>>> the field definitions. If the first record has a string
>>>>>> field and the value is zero length it won't give me the field
>>>>>> (though the field count is always correct). In addition, it
>>>>>> won't give me any fields after that either. If, however, I
>>>>>> make sure that field has some value (a dash, an "x",
>>>>>> whatever) then the field definition will come in correctly.
>>>>>> I still haven't narrowed down a problematic number field
>>>>>> though. Mind you, this is all done in MapServer PHP v. 4.2.0.
>>>>>> -Abe
>>>>>>>> A good amount of fields aren't showing up in MapServer for
>>>>>> me. I use
>>>>>>>> the following PHP script to dump out all layers and their
>>>>>> fields for
>>>>>>>> debugging. Does MapServer have problems with certain data
>>>>>> types or
>>>>>>>> certain values in a row?
>>>>>>> Are you using a tiled shapefile layer or is this a regular
>>>>>> shapefile
>>>>>>> layer?
>>>>>>> Daniel Morissette dmorissette at dmsolutions.ca
>>>>>>> DM Solutions Group http://www.dmsolutions.ca/
>>> Jeff McKenna
>>> GIS Specialist
>>> DM Solutions Group Inc.
