Shapefile field problem
Nicol Hermann
mapserver at GEOWORLD.DE
Tue Dec 7 17:29:14 EST 2004
Try adding a template tag to the layer section in your mapfile
e.g.
TEMPLATE "dummy.html"
getNumResults() are now 1
Nicol
Am Di, den 07.12.2004 schrieb Abe Gillespie um 23:19:
> Ok, you've proven to me you can *force* MapServer to give you the names
> of problem fields. But try this one (use the newly edited DBF file):
> <html>
> <body>
> dl("php_mapscript.so");
> $map = ms_newMapObj("/Users/abe/Sites/ms_test/test.map");
> for ($i = 0; $i < $map->numlayers; $i++)
> $l = $map->getLayer($i);
> putBrLine($l->name.", type: ".$l->type);
> // Query test.
> @$l->queryByAttributes("CITY", "/foo/", MS_MULTIPLE);
> putBrLine($l->getNumResults());
> if ($l->data != null) // Shape files with data.
> $l->open();
> $s = $l->getShape(-1, 0);
> $vals = $s->values;
> putBrLine("field count: ".count($vals));
> while ($fld = current($vals))
> putBrLine(" ".key($vals));
> next($vals);
> foreach ($vals as $key => $val) {
> printf ("%s -- %s<br>\n", $key, $val);
> $s->free();
> $l->close();
> function putBrLine($line)
> echo "$line<br>\n";
> </body>
> </html>
> For me I get 0 as the number of results but you can clearly see the
> value getting dumped out. Barring I didn't screw up the query, this is
> a problem no?
> Thanks as always.
> -Abe
> ______________________________________________________________________
> On Dec 7, 2004, at 4:30 PM, Nicol Hermann wrote:
> > Hi Abe,
> > i modified your script.
> > Instead of 'while' i use the following 'foreach' loop.
> > printf ("%s -- %s\n", $key, $val);
> > This statement returns all 54 fields of your shapefile.
> > HTH
> > Nicol
> > Am Di, den 07.12.2004 schrieb Abe Gillespie um 22:17:
> >> The problem with adding a value for that attribute corrupts the test
> >> case. Can you try the following PHP code and compare your results
> >> with
> >> mine?
> >> [php]
> >> <html>
> >> <body>
> >> $map =
> >> data.
> >> $l->open();
> >> $vals = $s->values;
> >> ".count($vals));
> >> next($vals);
> >> $s->free();
> >> $l->close();
> >> echo "$line<br>¥n";
> >> </body>
> >> </html>
> >> [output]
> >> test, type: 2
> >> field count: 54
> >> ACAD_TEXT
> >> COUNT
> >> ACCOUNT_NU
> >> See how there's a discrepancy between the field count and the number
> >> of
> >> field names that get dumped? From my experience, the field just after
> >> ACCOUNT_NU has a NULL value. I see the same behavior on my Mac OS X
> >> and Debian Linux installs.
> >> -Abe
> >> On Dec 7, 2004, at 2:15 PM, Jeff McKenna wrote:
> >>> Abe,
> >>> I made a tiny mapfile with your test shp, and i see labels properly
> >>> in
> >>> MapServer with it. I added an attribute in the "OWNERS_NAM" field
> >>> and
> >>> I successfully displayed it in mapserver. Am i misunderstanding your
> >>> problem somehow? (mapfile below)
> >>> jeff
> >>> MAP
> >>> NAME "field-test"
> >>> STATUS ON
> >>> EXTENT 1260565.500000 941362.000000 1261605.125000 942198.625000
> >>> SIZE 400 300
> >>> SHAPEPATH "D:/DMSG/projects/mapserver-bugs/"
> >>> SYMBOLSET "../etc/symbols.sym"
> >>> FONTSET "../etc/fonts.txt"
> >>> IMAGETYPE gif
> >>> IMAGECOLOR 255 255 255
> >>> UNITS METERS
> >>> WEB
> >>> IMAGEPATH "/ms4w/tmp/ms_tmp/"
> >>> IMAGEURL "/ms_tmp/"
> >>> METADATA
> >>> END
> >>> END
> >>> OUTPUTFORMAT
> >>> NAME "gif"
> >>> MIMETYPE "image/gif"
> >>> DRIVER "GD/GIF"
> >>> EXTENSION "gif"
> >>> IMAGEMODE PC256
> >>> TRANSPARENT FALSE
> >>> END
> >>> LAYER
> >>> NAME test
> >>> TYPE POLYGON
> >>> STATUS ON
> >>> DATA test
> >>> LabelItem "OWNERS_NAM"
> >>> CLASS
> >>> NAME "ttt"
> >>> COLOR 0 255 0
> >>> LABEL
> >>> COLOR 255 0 0
> >>> FONT fritqat-italic
> >>> TYPE truetype
> >>> SIZE 8
> >>> POSITION AUTO
> >>> PARTIALS FALSE
> >>> OUTLINECOLOR 255 255 255
> >>> END
> >>> END
> >>> END # Layer
> >>> END
> >>> Abe Gillespie wrote:
> >>>> I do appreciate the help, but I'm not looking for an "external to
> >>>> MapServer" way of getting access to my DBF field values. I just use
> >>>> my
> >>>> PHP script to *reveal* problematic shapefile fields. When there is
> >>>> a
> >>>> problem it's unusable to MapServer! I.e.: I can't use the field for
> >>>> labelling.
> >>>> -Abe
> >>>> On Dec 7, 2004, at 11:27 AM, Ryan, Adam wrote:
> >>>>> Abe,
> >>>>> Here's a routine I use to get the header information (field info)
> >>>>> from
> >>>>> a dbf
> >>>>> file.
> >>>>> // ========== iDbf_fields ==============
> >>>>> // $f is a dbf file path, returns an array of field arrays
> >>>>> function iDbf_fields($f){
> >>>>> $h = fopen($f,"rb");
> >>>>> $a =
> >>>>> unpack("cversion/cyy/cmm/cdd/inumrecs/sheadsize/
> >>>>> srecsize",fread($h,12));
> >>>>> fread($h,20); //skip some reserved space
> >>>>> for($i=0;$i<($a["headsize"]-33)/32;$i++){
> >>>>> $fa = array();
> >>>>> $fname = trim(fread($h,11));
> >>>>> $fa["type"] = fread($h,1);
> >>>>> fread($h,4);
> >>>>> $fa =
> >>>>> array_merge($fa,unpack("Clen/Cpre",fread($h,2)));
> >>>>> fread($h,14);
> >>>>> $flds[$fname] = $fa;
> >>>>> fclose($h);
> >>>>> return $flds;
> >>>>> When I generate a result table I'll go through the array like this:
> >>>>> ($so is
> >>>>> the shape Object)
> >>>>> foreach($flds as $fname => $fA){
> >>>>> $val = $so->values[$fname];
> >>>>> if ($val==null)$val=" ";
> >>>>> $val = str_replace(" ","
> >>>>> ",$val);
> >>>>> if ($fA["type"]=="D"){$val =
> >>>>> substr($val,4,2)."-".substr($val,6,2)."-".substr($val,0,4);}
> >>>>> echo "<td>$val</td>";}
> >>>>> Cheers to all,
> >>>>> Adam
> >>>>>> -----Original Message-----
> >>>>>> From: Abe Gillespie [mailto:agillesp at VT.EDU]
> >>>>>> Sent: Monday, December 06, 2004 5:14 PM
> >>>>>> To: MAPSERVER-USERS at LISTS.UMN.EDU
> >>>>>> Subject: Re: [UMN_MAPSERVER-USERS] Shapefile field problem
> >>>>>> It's a regular shapefile. I think I've mostly narrowed it
> >>>>>> down. It seems to me (though I may be completely off) that
> >>>>>> MapServer loads the first record of the DBF in order to get
> >>>>>> the field definitions. If the first record has a string
> >>>>>> field and the value is zero length it won't give me the field
> >>>>>> (though the field count is always correct). In addition, it
> >>>>>> won't give me any fields after that either. If, however, I
> >>>>>> make sure that field has some value (a dash, an "x",
> >>>>>> whatever) then the field definition will come in correctly.
> >>>>>> I still haven't narrowed down a problematic number field
> >>>>>> though. Mind you, this is all done in MapServer PHP v. 4.2.0.
> >>>>>> -Abe
> >>>>>>>> A good amount of fields aren't showing up in MapServer for
> >>>>>> me. I use
> >>>>>>>> the following PHP script to dump out all layers and their
> >>>>>> fields for
> >>>>>>>> debugging. Does MapServer have problems with certain data
> >>>>>> types or
> >>>>>>>> certain values in a row?
> >>>>>>> Are you using a tiled shapefile layer or is this a regular
> >>>>>> shapefile
> >>>>>>> layer?
> >>>>>>> Daniel Morissette dmorissette at dmsolutions.ca
> >>>>>>> DM Solutions Group http://www.dmsolutions.ca/
> >>> Jeff McKenna
> >>> GIS Specialist
> >>> DM Solutions Group Inc.
(o -) Dipl.-Geogr. Nicol Hermann
-------ooO-(_)-Ooo-----------------------------------------------
Chattenstraße 67
.oooO 55130 Mainz
( ) Oooo. Tel. 06131/6007550
\_) ) / http://www.nicol.info
(_/ E-Mail: nicol at nicol.info
WWW-Tip!
Geographisches Informationssystem
http://www.geoworld.de/
