Gix 0.3 released
Eduin Carrillo
yecarrillo at YAHOO.COM
Fri Dec 10 17:11:08 EST 2004
A new version of Gix has come.
http://gix.sourceforge.net
Changes:
- View2MAP: More flexible options for almost all objects values in the export
process
- View2MAP: Full support for overlayed symbols (CompositePen, CompositeMarker,
CompositeFill) using STYLE objects if version > 4
- View2MAP: Reference image exported as JPG. No more jpg2gif conversion.
- Full support for Quantum GIS projects
- Experimental support for OpenEv projects
- Fixed Error when exporting views with Image Themes in all View export formats
(bug 1046091)
- Full support to exporting View to Thuban Session format
(http://thuban.intevation.org/)
- View2MAP: Fixed string fields with single quote in themes with definition SQL
(FILTER)
- View2MAP: Symbols can be named by Layer index instead of layer name
(optional)
- Fixed filename in Export Themes Dialog
- Themes2SQL: Added ALTER TABLE DROP CONSTRAINT command
- View2MAP: Fixed Extension bug when Language Packs for ArcView are installed
(make, install, uninstall scripts)
- View2MAP: Added support for MapServer 4.4 features: ENCODING, wms_timeformat,
wms_default ...
More at:
http://sourceforge.net/project/shownotes.php?release_id=288991
Gix for ArcGis in under development. This port will be sponsored by
DMSolutions. ArcObjects developers interested in take part of this team are
welcome.
Eduin
Eduin Yesid Carrillo Vega
yecarrillo at yahoo.com
COLOMBIA
_________________________________________________________
Do You Yahoo!?
Información de Estados Unidos y América Latina, en Yahoo! Noticias.
Visítanos en http://noticias.espanol.yahoo.com
