Logging error messages, environment variable MS_ERRORFILE
Bart van den Eijnden
bartvde at XS4ALL.NL
Mon Dec 13 08:35:03 EST 2004
are you using Apache? You can then set the variable using SetEnv in the
httpd.conf.
Also on Windows, I could not get Mapserver to use the system (or user)
environment variables, I had to set them in Apache.
See also:
http://mapserver.gis.umn.edu/cgi-bin/wiki.pl?DebuggingMapserver
Best regards,
Bart
> Hi,
> I was told somewhere that I could set an environment variable called
> MS_ERRORFILE within system variables under Windows and assign a path
> to a text file for logging purposes. Then UMN-MapServer error messages
> are expected to be more communicative. I never testet it under
> Windows, I need this for Unix/Linux systems. I tried to set this
> variable in a shell, but UMN-MapServer doesn't write anything to the
> assigned file.
> Background for this are error messages like "Cannot draw layer XYZ".
> It would be really helpful, to have more information about this
> "Cannot" :-)!
> Any ideas? Any ideas about this MS_ERRORFILE. You'll find the
> following line in maperror.c (that is not the only appearance)
> errfile = getenv("MS_ERRORFILE");
> Maybe that is a questions which would better be addressed to the dev-list?
> Kind Regards,
> Benjamin
