Trouble with build on new machine
Daryl Herzmann
akrherz at IASTATE.EDU
Tue Dec 14 17:27:48 EST 2004
Hi Joseph,
On Tue, 14 Dec 2004, Joseph Norris wrote:
> Hello,
> I am installing mapserver on a new linux box and I am getting this on the
> make:
> ./libmap.a(mapwfslayer.o)(.text+0x9e): In function `msBuildRequestParams':
> : undefined reference to `msOWSLookupMetadata'
> ./libmap.a(mapwfslayer.o)(.text+0xcd): In function `msBuildRequestParams':
> ./libmap.a(mapwfslayer.o)(.text+0xfd): In function `msBuildRequestParams':
> ./libmap.a(mapwfslayer.o)(.text+0x12d): In function `msBuildRequestParams':
> ./libmap.a(mapwfslayer.o)(.text+0x152): In function `msBuildRequestParams':
> collect2: ld returned 1 exit status
> make: *** [shp2img] Error 1
> Am I missing something or is there a configure option I should be using?
Did you start over with a new archive extract on this new machine? Or did
you copy over your build directory from the old machine? Either way, send
along the ./configure options and make sure that you do a 'make clean'
before building...
daryl
* Daryl Herzmann (akrherz at iastate.edu)
* Program Assistant -- Iowa Environmental Mesonet
* http://mesonet.agron.iastate.edu
