More than one symbol for one point
"Guillaume SUEUR (Géosignal)"
guillaume.sueur at GEOSIGNAL.FR
Wed Dec 15 03:43:24 EST 2004
What I do to solve ths kind of problem is to render the symbols after
the map, with the addPoint method. I parse my data table after the map
is rendered and add my pins on it. I just need to have X and Y fields in
the data table, not even a true spatial one.
Guillaume
Holger Floerke wrote:
> Your mail has been scanned by InterScan VirusWall.
> May it be an option to use a symbol font and "pre-render" strings within the
> data corresponding to the features of the point (airport, station,...)? Then
> I can use the labels to draw the strings with the symbol font and I will get
> all the symbols in a row.
> Anybody does this before?
> HolgeR
>>>Is it possible to draw more than one symbol (dependent on some data
>>>fields)
>>>for one point of a point layer? For example drawing cities with a circle,
>>>but if the city has an airport (data value "[airport]=1"), then draw an
>>>additional airport symbol near the city without having another airport
>>>layer.
>>>Thanks in advance,
>>>HolgeR
>>You would need to adjust the symbol definitions to move the symbols out
>>of the way of each other. These examples just stack two different
>>symbols on top of one another.
>>This might help get you started (i don't believe it can be used with
>>more than two symbols though)
Guillaume SUEUR
GEOSIGNAL - Groupe BVA
25bis Avenue Marcel Dassault
31505 TOULOUSE CEDEX 5
