Troubles with java mapscript compilation on windows
Karel Cernohorsky
cernohor at CENTRUM.CZ
Thu Dec 16 09:38:13 EST 2004
Thans Frank,
Win32 Compilation and Installation HOWTO helped me a lot.
But journey continue.
I am now trying to compile java mapscript and I have a similar problems :(
Now I have compiled mapserver succesfuly.
mapserv -v
MapServer version 4.5 OUTPUT=GIF OUTPUT=PNG OUTPUT=JPEG OUTPUT=WBMP
SUPPORTS=PROJ SUPPORTS=FREETYPE
SUPPORTS=WMS_SERVER INPUT=SHAPEFILE DEBUG=MSDEBUG
Is there any similar HOWTO concerning java mapscript compilation on windows?
makefile.vc for java mapscrip ends with this error.
But I dont understand it well, but is seems like problems with layers.
Am I missing some library or what?
mapscript_wrap.c
link /dll /debug mapscript_wrap.obj
d:\MapServerSupportProjects\gdwin32/bgd.lib d:\M
apServerSupportProjects\proj-4.4.9/src/proj_i.lib
..\..\mapserver_i.lib /NODEFAULTLIB
:"MSVCRTD" /NODEFAULTLIB:libcd /NODEFAULTLIB:libcmtd /NODEFAULTLIB:msvcrtd
/NODEFAULTLIB:LIBC /DEBUG
/def:..\..\mapserver.def /out:mapscript.dll /implib:mapscript_i.lib
Microsoft (R) Incremental Linker Version 7.00.9466
Copyright (C) Microsoft Corporation. All rights reserved.
Creating library mapscript_i.lib and object mapscript_i.exp
mapscript_wrap.obj : error LNK2019: unresolved external symbol
_msSLDApplySLD referenced in function
_layerObj_applySLD
_msSLDApplySLDURL referenced in funct
ion _layerObj_applySLDURL
_msSLDGenerateSLD referenced in funct
ion _layerObj_generateSLD
mapscript.dll : fatal error LNK1120: 3 unresolved externals
NMAKE : fatal error U1077: 'link' : return code '0x460'
Stop.
I am looking forward to read any hints,
Karel.
----- Original Message -----
To: <MAPSERVER-USERS at LISTS.UMN.EDU>
Sent: Wednesday, December 15, 2004 6:04 PM
Subject: Re: [UMN_MAPSERVER-USERS] Troubles with regex-0.12
> Karel,
> I would suggest you review:
> http://mapserver.gis.umn.edu/doc44/win32_compile-howto.html
> In particular there is a section that reads:
> Regex Build Problems.
> regex.obj : error LNK2001: unresolved external symbol _printchar
> libmap.dll : fatal error LNK1120: 1 unresolved externals
> Stop.
> This occurs if you use the stock regex-0.12 we referenced. I work
> around this by commenting out the "extern" statement for the
> printchar() function, and replacing it with a stub implementation in
> regex-0.12\regex.c.
> //extern void printchar ();
> void printchar( int i ) {}
> Best regards,
> I set the clouds in motion - turn up | Frank Warmerdam,
warmerdam at pobox.com
> light and sound - activate the windows | http://pobox.com/~warmerdam
> and watch the world go round - Rush | Geospatial Programmer for Rent
Odchozí zpráva neobsahuje viry.
Zkontrolováno antivirovým systémem AVG (http://www.grisoft.cz).
Verze: 6.0.811 / Virová báze: 552 - datum vydání: 13.12.2004
