oracle spatial troubles
Fernando S.
fsimon at UNIVALI.BR
Thu Dec 16 11:49:16 EST 2004
Hi Francesco,
In this last version (4.4) the Oracle driver change.
So, how did you defined your layer data string?
Are you using Linux (*nix) or Windows? Some users report error with
Windows binaries, Linux are working. I'm working to find the problem.
Thanks.
Fernando Simon - simon at inf.univali.br
Mapserver and Oracle Spatial developer
G10 - Laboratorio de Computacao Aplicada
http://g10.cttmar.univali.br
Francesco Sozzi wrote:
>Hi all,
>MAPSERVER 4.4
>I'm trying reading oracle spatial tables from a server Oracle 9i Enterprise
>Edition by use of mapserver 4.4.0.
>The problem is that on submitting map file from browser, in one machine I
>get a general protection fault, and in another I get a CGI error. In both
>case I can't read any oracle spatial data.
>I have to say that my mapserver installation works fine with shp and
>rasters. I have troubles only with oracle.
>MAPSERVER 4.2
>I've also tried this version, and it works a little better. In this case I
>can renderer points and lines, but if I try to renderer a polygon I get an
>error (mapserver says that it finds no polygon geometry). These tables work
>fine with other products (MapGuide, ArcView, MapObject, ecc...).
>Anybody can suggest me something?...
>regards
>Francesco
