Does the 4.4.0 windows binary really support SWF?
Frans Knibbe
frans at GEODAN.NL
Fri Dec 17 03:44:57 EST 2004
Thank you for the pointer. However, I am not sure I entirely understand.
Does MapServer only support image (GDAL) output at the moment, that is,
PDF and SWF are not supported? Is it only the precompiled windows binary
that does not support these formats or is it in general not possible to
enable support for non-image output?
Yewondwossen Assefa wrote:
> Bug http://mapserver.gis.umn.edu/bugs/show_bug.cgi?id=455 describes
> this issue. Only GDAL/GD formats are supported for wms in 4.4. This
> will be upgadred to other formats for 4.6 release.
> Frans Knibbe wrote:
>> Hello,
>> I have downloaded and installed the binary Windows distribution, version
>> 4.4.0. In the description on the website, it says the binaries are build
>> with SWF support. When I do a request for capabilities, SWF is mentioned
>> in a comment in the output XML file, but does not show up as a supported
>> GetMap output format. Indeed, when I request a map in SWF format,
>> the following error is returned:
>> msWMSLoadGetMapParams(): Image handling error. Unsupported output format
>> (application/x-shockwave-flash).
>> Am I doing something wrong or is the text accompanying the binaries
>> wrong?
>> Greetings,
>> Frans
