php dso and the mapserv cgi
Miroslav Šulc
miroslav.sulc at STARTNET.CZ
Fri Dec 17 15:16:21 EST 2004
I have the same problem with MapServer and PHP 5.0.2 (and I am also on
Gentoo). I thougth that the problem is on my side but I decided to use
only PHP MapScript which showed up can give me what I want. Up to that,
I didn't find any way to find out what's wrong with the CGI.
Miroslav ulc
Ken-ichi wrote:
> Hi all. I tried compiling MapServer against PHP 4.3.10 compiled as an
> Apache DSO, given recent messages on this list suggesting this was now
> possible. PHP MapScript seems to work fine, but the mapserv cgi just
> gives 500 errors, and the error log says "Premature end of script
> headers: mapserv". I've tried adding lines to httpd.conf specifying the
> LD_LIBRARY_PATH to all relevant directories, and updating my environment
> variables (env-update, as I'm on Gentoo), but with no luck. Any idea
> what's going on? I don't understand why the mapserv cgi even cares how
> php is running. It's not even using php!
> Oh, and here are my configure statements, if it helps:
> APACHE
> ./configure \
> --with-openssl \
> --with-zlib \
> --with-dbase \
> --with-dbx \
> --with-gd=/usr \
> --with-jpeg-dir=/usr \
> --with-png-dir=/usr \
> --with-zlib-dir=/usr \
> --with-freetype-dir=/usr \
> --with-mcrypt \
> --with-pdflib=/usr \
> --with-pgsql \
> --with-pspell \
> --with-pear \
> --with-apxs2=/usr/local/apache2/bin/apxs \
> --enable-force-cgi-redirect \
> --enable-discard-path \
> --with-regex=system
> MAPSERVER
> ./configure
> --with-gd=/usr \
> --with-freetype=/usr \
> --with-zlib=/usr \
> --with-png=/usr \
> --with-jpeg=/usr \
> --with-pdf=/usr \
> --with-proj=/usr \
> --with-ogr=/usr/local/bin/gdal-config \
> --with-gdal=/usr/local/bin/gdal-config \
> --with-postgis=/usr/local/pgsql/bin/pg_config \
> --with-wfs \
> --with-wmsclient \
> --with-wfsclient \
> --with-curl-config=/usr/bin/curl-config \
> --with-httpd=/usr/local/apache2/bin/httpd \
> --with-php=/usr/local/src/php-4.3.10 \
> --without-tiff
> -Ken-ichi
Type: text/x-vcard
Desc: not available
Url : http://lists.osgeo.org/pipermail/mapserver-users/attachments/20041217/aca72d93/miroslav.sulc.vcf
