getShape and getFeature
Sean Gillies
sgillies at FRII.COM
Tue Dec 21 13:10:01 EST 2004
On Dec 21, 2004, at 10:22 AM, Eduin Carrillo wrote:
> --- Sean Gillies <sgillies at FRII.COM> escribió:
>> Eduin,
>> The getShape method works as it always did. The getFeature method is
>> explained in mapscript/doc/mapscript.txt and
>> mapscript/doc/querying-HOWTO.txt.
>> Sean
>> Sean Gillies
>> sgillies at frii dot com
>> http://users.frii.com/sgillies
> Thanks Sean.
> ArcGIS reports this error on GetFeature with the identify tool:
> Warning: array_keys(): The first argument should be an array in
> /usr/local/apache2/htdocs/servlet/GetFeatures.php on line 396
> Seems getShape are not restoring values as expected(array). I think is
> not a
> IMSEmu problem.
> $ashape = $lyr->getShape(-1, 0);
> $attributeCount = 0;
> $namearray = array_keys($ashape->values);
Eduin,
My mistake ... I thought you were talking about the IMS emulator for
Perl and the Perl mapscript. I'm not a PHP user and I don't have any
experience that can help you.
Disregard my references to those documents, they will not help you with
PHP mapscript.
Sean
Sean Gillies
