ArcIMS Emulator and ArcGIS 9sp2
Eduin Carrillo
yecarrillo at YAHOO.COM
Wed Dec 22 10:22:03 EST 2004
--- Ed McNierney <ed at TOPOZONE.COM> escribió:
> Berend -
> Yes, this is a significant change in SP2, and will require some
> noticeable rework - the "WKT" description of the projections is, of
> course, the ESRI-flavored variant. For example, your DATUM string
> begins with "D_", which isn't what the emulator expects. I've asked
> about this before and didn't hear any response about it.
> Of course, SP2 breaks ArcIMS emulators, but it also adds WMS support
> into the core product; see
> http://downloads.esri.com/support/downloads/ao_/ArcGIS-90sp2-WMS-spt.pdf
> for the instructions. As a result, I'm inclined to abandon further
> ArcIMS emulation support and tell ESRI users to use WMS!
> - Ed
> Ed McNierney
> President and Chief Mapmaker
> TopoZone.com / Maps a la carte, Inc.
> 73 Princeton Street, Suite 305
> North Chelmsford, MA 01863
> ed at topozone.com
> (978) 251-4242
> -----Original Message-----
> From: UMN MapServer Users List [mailto:MAPSERVER-USERS at LISTS.UMN.EDU] On
> Behalf Of Berend Veldkamp
> Sent: Wednesday, December 22, 2004 6:31 AM
> To: MAPSERVER-USERS at LISTS.UMN.EDU
> Subject: [UMN_MAPSERVER-USERS] ArcIMS Emulator and ArcGIS 9sp2
> Is anyone using the ArcIMS Emulator from Refractions with ArcGIS 9,
> service pack 2? It works without problems in 9, but after installing
> sp2, no images are created.
> It seems Esri has a different way of specifying the coordinate system,
> it used to be simply <FEATURECOORDSYS id="28992"/>, but now it's
> <FEATURECOORDSYS string="PROJCS["RD_New",
> GEOGCS["GCS_Amersfoort",
> DATUM["D_Amersfoort", SPHEROID["Bessel_1841",
> 6377397.155,299.1528128]], PRIMEM["Greenwich",0.0],
> UNIT["Degree" ,0.0174532925199433]],
> PROJECTION["Double_Stereographic"],
> PARAMETER["False_Easting", 155000.0],
> PARAMETER["False_Northing", 463000.0],
> PARAMETER["Central_Meridian", 5.38763888888889],
> PARAMETER["Scale_Factor", 0.9999079],
> PARAMETER["Latitude_Of_Origin", 52.15616055555555],
> UNIT["Meter", 1.0]]"></FEATURECOORDSYS>
> In the php logfile I find:
> Projecting Envelope from to init=epsg:28992
> Thanks, Berend
> ____________________________
> Berend Veldkamp - ARIS
> http://www.aris.nl/
I still interested providing access through IMS Services. I think IMSEmulator
is a good strike from OpenSource to ESRI excluding politics.It grant access to
free other clients as ArcExplorer Java.
IMSEmulator has not been mostly used. IMSEmu mailing list has ONLY 2 messages!
(http://mapserver.refractions.net/pipermail/imsemu-devel), but I think it is a
good tool.
For this new ESRI strike, could exists a workaround. Looking at PostGIS system
tables, we can connect ESRI projection code with WKT projection text (srid and
srtext fields from spatial_ref_sys table).
Based on client version, we can send proj "id" or proj "string".
Paul Ramsey at Refractions can include this code in next version.
Eduin Yesid Carrillo Vega
yecarrillo at yahoo.com
COLOMBIA
_________________________________________________________
Do You Yahoo!?
Información de Estados Unidos y América Latina, en Yahoo! Noticias.
Visítanos en http://noticias.espanol.yahoo.com
