ArcIMS Emulator and ArcGIS 9sp2
Ed McNierney
ed at TOPOZONE.COM
Wed Dec 22 09:50:16 EST 2004
Berend -
Yes, this is a significant change in SP2, and will require some
noticeable rework - the "WKT" description of the projections is, of
course, the ESRI-flavored variant. For example, your DATUM string
begins with "D_", which isn't what the emulator expects. I've asked
about this before and didn't hear any response about it.
Of course, SP2 breaks ArcIMS emulators, but it also adds WMS support
into the core product; see
http://downloads.esri.com/support/downloads/ao_/ArcGIS-90sp2-WMS-spt.pdf
for the instructions. As a result, I'm inclined to abandon further
ArcIMS emulation support and tell ESRI users to use WMS!
- Ed
Ed McNierney
President and Chief Mapmaker
TopoZone.com / Maps a la carte, Inc.
73 Princeton Street, Suite 305
North Chelmsford, MA 01863
ed at topozone.com
(978) 251-4242
-----Original Message-----
From: UMN MapServer Users List [mailto:MAPSERVER-USERS at LISTS.UMN.EDU] On
Behalf Of Berend Veldkamp
Sent: Wednesday, December 22, 2004 6:31 AM
To: MAPSERVER-USERS at LISTS.UMN.EDU
Subject: [UMN_MAPSERVER-USERS] ArcIMS Emulator and ArcGIS 9sp2
Is anyone using the ArcIMS Emulator from Refractions with ArcGIS 9,
service pack 2? It works without problems in 9, but after installing
sp2, no images are created.
It seems Esri has a different way of specifying the coordinate system,
it used to be simply <FEATURECOORDSYS id="28992"/>, but now it's
<FEATURECOORDSYS string="PROJCS["RD_New",
GEOGCS["GCS_Amersfoort",
DATUM["D_Amersfoort", SPHEROID["Bessel_1841",
6377397.155,299.1528128]], PRIMEM["Greenwich",0.0],
UNIT["Degree" ,0.0174532925199433]],
PROJECTION["Double_Stereographic"],
PARAMETER["False_Easting", 155000.0],
PARAMETER["False_Northing", 463000.0],
PARAMETER["Central_Meridian", 5.38763888888889],
PARAMETER["Scale_Factor", 0.9999079],
PARAMETER["Latitude_Of_Origin", 52.15616055555555],
UNIT["Meter", 1.0]]"></FEATURECOORDSYS>
In the php logfile I find:
Projecting Envelope from to init=epsg:28992
Thanks, Berend
____________________________
Berend Veldkamp - ARIS
http://www.aris.nl/
