SLD and transparent polygon fill
Sean Gillies
sgillies at FRII.COM
Thu Dec 23 12:12:41 EST 2004
On Dec 23, 2004, at 9:59 AM, Bart van den Eijnden wrote:
> Hi list,
> is it possible using Mapserver to have a transparent polygon fill
> through
> SLD?
> E.g.:
> <Fill>
> <CssParameter name="fill">#ff0000</CssParameter>
> <CssParameter name="fill-opacity">0.5</CssParameter>
> </Fill>
> If not, is there a work-around to accomplish this using SLD?
> Thanks in advance.
> Best regards,
> Bart
One problem you will run into is that MapServer only has layer-level
transparency and cannot have transparency defined at the style
(symbolizer) level. I'm not sure how the MapServer OGC SLD programmers
have worked around this.
Sean
Sean Gillies
sgillies at frii dot com
http://users.frii.com/sgillies
