PHP/Mapscript,
Find what Shape of layer one is each point of layer 2 in
Ed Martin
edman007x at MAC.COM
Fri Dec 24 19:34:18 EST 2004
i have a layer of cities and a layer of counties, and right now i'm
trying to make a table in mysql of that county each city is in, the
problem is i can't figure out how should go about doing this, what i
have done so far is make an array of all the points in the cities
layer, but then after that i'm stuck as to how to determine what county
that point it is in, this is the code i have so far, and i just get
thousands of errors saying nothing found
-----code-----
$map = ms_newMapObj("map/map.map");
$cities = $map->getlayerbyname('Cities');
$counties = $map->getlayerbyname('County');
$cities->open();
$id = 0;
$query = 'SELECT id FROM cities ORDER BY id DESC';
$result= mysql_query($query);
$id_max = mysql_fetch_array($result, MYSQL_NUM);
$id_max[0]--;
//get the shape, then line, then point for each city
while ($city_shape[$id] = $cities->getshape(-1, $id)){
if ($id >= $id_max[0]){
break;
$id++;
$cities->close();
$size = sizeof($city_shape);
$dont_touch = array();
for ($i = 0; $i<$size; $i++){
$city_line[$i] = $city_shape[$i]->line(0);
if (!is_object($city_line[$i])){
$dont_touch[] = $i;//for some reason 3 lines return false
instead of a point
//so this makes an array of those so they can be skipped
if (in_array($i, $dont_touch)){
continue;//skip the non-objects
$city_point[$i] = $city_line[$i]->point(0);
$counties->querybypoint($city_point[$i], MS_SINGLE, 1);//this justs
gives errors
//once i can get the id of the county i feel i will be able to dump
it to mysql
---relevant parts of mapfile---
MAP
#The First layer is drawn first so it will be under everything else
NAME "Ads By Town"
EXTENT -126.30536309017 6.3903743998824 -63.798263662392
68.919064491698
# EXTENT -179.133 17.675 179.788 71.398
IMAGETYPE jpeg
IMAGECOLOR -1 -1 -1
STATUS ON
SIZE 600 600
UNITS dd
SYMBOLSET "symbols.txt"
OUTPUTFORMAT
NAME jpeg
DRIVER "GD/JPEG"
MIMETYPE "image/jpeg"
IMAGEMODE RGB
EXTENSION "jpg"
FORMATOPTION "QUALITY=65"
END
#layer for the counties
LAYER
NAME "County"
TYPE POLYGON
STATUS DEFAULT
DATA
"/usr/local/apache/htdocs/adsbytown/mapserver/map/data/countyp020"
MAXSCALE 8203600
CLASS
NAME "County Boarder"
STYLE
OUTLINECOLOR 0 200 200
SYMBOL "dashed_line"
SIZE 1
END
END
END
#layer for the cities
LAYER
NAME "Cities"
TYPE POINT
STATUS default
DATA "/usr/local/apache/htdocs/adsbytown/mapserver/map/data/ci10de03"
LABELMAXSCALE 1025400
LABELITEM "NAME"
MAXSCALE 4101800
LABELCACHE on
TOLERANCE 25
TOLERANCEUNITS miles
METADATA
"title" "Ads By Town Cities"
"author" "Me!"
END
#this is for cities default
CLASS
TEMPLATE void
NAME "City"
LABEL
ANGLE 0
ANTIALIAS FALSE
COLOR 0 0 0
SIZE small
TYPE bitmap
BUFFER 2
OFFSET 0 5
POSITION lc
#FORCE TRUE#force everything to be labeled (text overlaps)
END
STYLE
OUTLINECOLOR 255 0 0
COLOR 255 0 0
SYMBOL 1
SIZE 2
END
END
