Mapscript issues...
Jeff Portwine
jdport at VERITIME.COM
Tue Dec 28 09:43:29 EST 2004
I'm brand new to mapserver and mapscript and am just starting to attempt to learn how to use it. I got it all installed, I believe correctly. I decided to start with the "Simple Recipes" scripts as a starting point to figuring everything out, but when I run the first example, hello.phtml I get an Internal Server Error. Looking at the error logs, I see:
/usr/local/apache2/cgi-bin/php: relocation error: /var/php/extensions/php_mapscript.so: undefined symbol: gdImageGifCtx
This is with mapserver-4.4.0 and php-4.3.4 under RedHat 9.0 if that helps.
When I do a test with phpinfo, I do see the mapscript extension listed properly and as far as I can tell I have everything installed properly. Does anybody have any suggestions on what the problem might be, and any links that might help smooth the learning curve would be appreciated as well. Thanks!
-Jeff
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20041228/2aeb0c22/attachment.html
