curl win32 compilation
Bart van den Eijnden
bartvde at XS4ALL.NL
Wed Dec 29 06:25:53 EST 2004
Hi list,
I have just finished compiling curl on win32 in order to enable Mapserver
as a WMS client, and I thought my notes might be helpful to people as this
is not part of the general Win32 compilation HOWTO.
What I did is use the MSVC version of curl available for download from the
curl site, I did not try to compile curl myself. Here are my instructions:
Added WMS client support:
Downloaded Curl from http://curl.haxx.se/download.html
Win32 - MSVC version, but it misses curlver.h, so also downloaded:
curl-7.12.2.zip.
And copied curlver.h to C:\projects\curl-7.12.2\include\curl\curlver.h
Moved libcurl.lib to C:\projects\curl-7.12.2\lib
Error encountered:
Creating library mapserver_i.lib and object mapserver_i.exp
maphttp.obj : error LNK2001: unresolved external symbol __imp__select at 20
libmap.dll : fatal error LNK1120: 1 unresolved externals
NMAKE : fatal error U1077: 'link' : return code '0x460'
Stop.
This was because I did not uncomment and configure the path to the following:
WINSOCK_LIB = "d:\program files\Microsoft Visual Studio\VC98\Lib\WSOCK32.LIB"
Copied libcurl.dll to the mapserv.exe directory, but now it is missing
zlibwapi.dll.
After a search I found this dll at:
http://www.winimage.com/zLibDll/
and more specific:
http://www.winimage.com/zLibDll/zlib122dll.zip
Best regards,
Bart
