curl win32 compilation
Bart van den Eijnden
bartvde at XS4ALL.NL
Wed Dec 29 11:15:14 EST 2004
Hi list,
I had some problems with this compile (mapserv occassionally crashing
because of an unhandled exception, internal server error) when requesting
for more than one layer in the WMS client.
So I tried a different approach compiling the curl-7.12.3 from source,
through the following commands:
C:\projects\curl-7.12.3\lib>nmake /f makefile.vc6 CFG=release
C:\projects\curl-7.12.3\lib>nmake /f makefile.vc6 CFG=release-dll
and changing nmake.opt of mapserv to also use libcurl_imp.lib:
CURL_LIB = $(CURL_DIR)/lib/libcurl.lib $(CURL_DIR)/lib/libcurl_imp.lib
But I still get the occassional crashing behaviour.
Is Mapserver not "compatible" with this version of libcurl, or am I doing
something wrong?
Best regards,
Bart
> Hi list,
> I have just finished compiling curl on win32 in order to enable Mapserver
> as a WMS client, and I thought my notes might be helpful to people as this
> is not part of the general Win32 compilation HOWTO.
> What I did is use the MSVC version of curl available for download from the
> curl site, I did not try to compile curl myself. Here are my instructions:
> Added WMS client support:
> Downloaded Curl from http://curl.haxx.se/download.html
> Win32 - MSVC version, but it misses curlver.h, so also downloaded:
> curl-7.12.2.zip.
> And copied curlver.h to C:\projects\curl-7.12.2\include\curl\curlver.h
> Moved libcurl.lib to C:\projects\curl-7.12.2\lib
> Error encountered:
> Creating library mapserver_i.lib and object mapserver_i.exp
> maphttp.obj : error LNK2001: unresolved external symbol __imp__select at 20
> libmap.dll : fatal error LNK1120: 1 unresolved externals
> NMAKE : fatal error U1077: 'link' : return code '0x460'
> Stop.
> This was because I did not uncomment and configure the path to the
> following:
> WINSOCK_LIB = "d:\program files\Microsoft Visual
> Studio\VC98\Lib\WSOCK32.LIB"
> Copied libcurl.dll to the mapserv.exe directory, but now it is missing
> zlibwapi.dll.
> After a search I found this dll at:
> http://www.winimage.com/zLibDll/
> and more specific:
> http://www.winimage.com/zLibDll/zlib122dll.zip
> Best regards,
> Bart
