Displaying classes in a layer
Wouter Schaubroeck
wouter.schaubroeck at GMAIL.COM
Thu Dec 30 10:06:39 EST 2004
Hi all,
I'm just learning how to work with mapserver. I do this by following the
tutorial on http://terrasip.gis.umn.edu/projects/tutorial/.
But i'm stuck at example 1.3. My mapserver is configured correctly (I
think, because the two first are displayed correctly), and the mapfile
is also ok. But it doesn't work!!! What do I wrong?
This is the mapfile:
MAP
IMAGETYPE PNG
EXTENT 201621.496941 -294488.285333 1425518.020722 498254.511514
SIZE 400 300
SHAPEPATH "data"
IMAGECOLOR 255 255 255
PROJECTION
"proj=laea"
"ellps=clrk66"
"lat_0=45"
"lon_0=-100"
# Alternatively, you can specify an EPSG code.
# "init=epsg:2163"
END
# Start of LAYER DEFINITIONS ---------------------------------------------
LAYER # States polygon layer begins here
NAME states_poly
DATA states_ugl
STATUS DEFAULT
TYPE POLYGON
PROJECTION
"init=epsg:4269"
END
CLASSITEM "CLASS"
CLASS
EXPRESSION 'land'
COLOR 232 232 232
END
CLASS
EXPRESSION 'water'
COLOR 198 198 255
END
END # States polygon layer ends here
LAYER # States line layer begins here
NAME states_line
DATA states_ugl
STATUS DEFAULT
TYPE LINE
PROJECTION
"init=epsg:4269"
END
CLASSITEM "CLASS"
CLASS
EXPRESSION 'land'
COLOR 32 32 32
END
END # States line layer ends here
# End of LAYER DEFINITIONS -------------------------------
END # end of map file
Thx in advance!!!
Wouter Schaubroeck
