[Mapserver-users] Hidden Layer
Stephen Clark
stephen.clark at focus.ca
Mon Feb 2 16:24:48 EST 2004
Guillaume,
If you want the image layer to draw then place it above the vector layer in
the map file.
MS will only draw the layers you tell it to draw. Using the DEMO
application as an example, only select the layers that you want drawn then
click "refresh"
Stephen
----- Original Message -----
To: <mapserver-users at lists.gis.umn.edu>
Sent: Monday, February 02, 2004 9:29 AM
Subject: [Mapserver-users] Hidden Layer
> Hi List !
> i wonder how MS draws the map Layers.
> if i have an Image Layer completly hidden by a vector layer, will MS spend
time
> reading the Tiff File ? or will it ignore it ?
> my layer-renderers are scale-dependent but because the layer image is
hidden by
> the other layer at a given scale, i don't know if it is better to set its
> status to "OFF"
> regards
> Guillaume MOCCAND
> Mapserver-users mailing list
> Mapserver-users at lists.gis.umn.edu
> http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
