[Mapserver-users] Tutorial & Flash
Pericles Nacionales
nacional at cbs.umn.edu
Mon Feb 2 17:18:53 EST 2004
You need to check the MapServer wiki for FLASH info.
http://mapserver.gis.umn.edu/cgi-bin/wiki.pl?MapserverFlash
I suggest going through section two of the tutorial before you try
flash--you need html template to work with this format.
Good luck!
-Perry N.
On Mon, 2 Feb 2004, Stephen Crawford wrote:
> Hello All,
> I'm just starting out with MapServer, with the hope of eventually being
> able to use it with some of the maps I make in Flash. I have downloaded
> the already compiled Win32 binaries (GIF version), downloaded the demo,
> amd everything seems OK. I started working throught the tutorial, and
> everything works fine. However, in sec 1.8, "Changing the map's output
> format", if I try using IMAGETYPE SWF, I get this error messege:
> "Content-type: text/html msBuildPath: Unable to access file." Is this a
> problem with the compiled version I downloaded (though it says it
> supports the SWF output)? I'd greatly appreciate any advice.
> Thanks,
> Steve Crawford
> Stephen Crawford
> Center for Environmental Informatics
> GeoVISTA Center
> College of Earth and Mineral Sciences
> The Pennsylvania State University
> email: src176 at psu.edu
> Mapserver-users mailing list
> Mapserver-users at lists.gis.umn.edu
> http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
