[Mapserver-users] Re: onSubmit - jBox
Richard Greenwood
rich at greenwoodmap.com
Tue Feb 3 22:44:52 EST 2004
Steve McCrone wrote:
> Hello Richard,
> I have just posted this question, but thought I would also ask you since you
> have done simiar to what I am trying to do
> Here's what I've got -
> function setbox_handler(name, minx, miny, maxx, maxy, redraw) {
> document.mapserv.imgbox.value = minx + " " + miny + " " + maxx + " " +
> maxy;
> document.mapserv.imgxy.value = minx + " " + miny;
> document.mapserv.submit();
> function preSubmit(){
> <form method="GET" action="[program]" name="mapserv" onSubmit="preSubmit()">
> The setbox_handler function gets called when a "tool" is used, and
> therefore, the document appears to be submitted. However, the preSubmit()
> function does not get called. It only gets called when the user does a
> "refresh" (i.e.<input type="submit" value="Refresh/Query">)
> Can't figure out why the document.mapserv.submit(); statement will not
> actually submit the form in order to have my preSubmit() function called -
> strange.
I think this is a peculiarity of Javascript. The Javascript submit()
function simply submits the form "directly", it does not look at, or
process any of the attributes in the <FORM> tag. So to process the
preSubmit() function in setbox_handler() you need:
if (preSubmit()) {
assuming your preSubmit() function returns a boolean value, or if not
simply :
preSubmit();
Rich
Richard Greenwood
www.greenwoodmap.com
