[Mapserver-users] Too hard, too easy or too boring?
Keith Campbell
scoota at supanet.com
Wed Feb 4 16:14:22 EST 2004
Hi Perry,
Thanks for the suggestion. I've checked the Makefile and 'XTRALIBS= -lm
-lstdc++' is in there.
Keith
Pericles Nacionales wrote:
>I'm not a Solaris user but you might need additional FLAGS/LIBS to get
>MapServer to work on that platform. Look at XTRALIBS in your Makefile and
>make sure "-lm -lstdc++" are there. Perhaps it will work with other,
>comparable libs.
>Just guessing.
>-Perry
>On Tue, 3 Feb 2004, Keith Campbell wrote:
>>OK, just trying to get your attention. I posted this yesterday under a
>>different title and got no responses.
>>Here's the problem. I'm trying to compila an install a WFS Server
>>enabled Mapserver on a Solaris (this is proving to be a very frustrating
>>experience, no doubt partly due to my lack of knowledge of UNIX). I
>>think I've got all the libraries installed that I need, even though they
>>are in non-standard locations (it's not my server). The configure script
>>runs to completion and only seems to complain once:-
>>checking for httpd... /export/home/local/apache2/bin/httpd
>>awk: syntax error near line 1
>>awk: bailing out near line 1
>> /export/home/local/apache2/bin/httpd version is Apache/2.0.45 ().
>>Not sure what this means or what the implications are.
>>Anyway, this is what I fed into the configure:-
>>bash$ ./configure --with-jpeg=/export/home/local/util/jpeg
>>--with-freetype=/exp
>>ort/home/local/util/freetype --with-zlib=/export/home/local/util/zlib
>>--with-pn
>>g=/export/home/local/util/libpng
>>--with-libiconv=/export/home/local/util/libico
>>nv --with-gd=/export/home/local/util/gd-2.0.15
>>--with-proj=/export/home/local/u
>>til/proj --with-ogr=/export/home/local/util/gdal/apps/gdal-config
>>--with-gdal=
>>/export/home/local/util/gdal/apps/gdal-config --with-wfs --with-postgis
>>The make process ran for some time before spitting this out:-
>>ld: fatal: relocation error: R_SPARC_32: file ./libmap.a(mapogr.o):
>>symbol <unkn
>>own>: offset 0xfd6609c9 is non-aligned
>>symbol <unkn
>>own>: offset 0xfd660a09 is non-aligned
>>symbol <unkn
>>own>: offset 0xfd660a69 is non-aligned
>>symbol <unkn
>>own>: offset 0xfd660c29 is non-aligned
>>collect2: ld returned 1 exit status
>>make: *** [shp2img] Error 1
>>I can't find anything in the archives that points to the cause of this.
>>Can anybody help?
>>Thanks,
>>Keith
>>_______________________________________________
>>Mapserver-users mailing list
>>Mapserver-users at lists.gis.umn.edu
>>http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
