[Mapserver-users] Querying on multiple fields
Steve Lime
steve.lime at dnr.state.mn.us
Wed Feb 4 17:13:16 EST 2004
You shouldn't need qitem in either system, so it must not be being
initialized properly someplace. I checked the source and it looks like
doing an strdup on a NULL value must be the culprit on some platforms. I
just checked a fix into the development tree.
Steve
>>> Roger Boily <boily at bsw.org> 2/4/2004 2:33:06 AM >>>
Hi to all,
after hundred of tests, I've found the hic..
When using the qstring argument in the format <'[FIELD]'=value>, on
MapServer running on Windows,
you do not need to add the qitem argument (as read somewhere...), but
you need it on a Linux machine....
So the failing link will become:
http://213.45.107.14/cgi-bin/mapserv?&map=/var/www/html/sittel/procida/urbis.map&layer=fogli&mapext=shapes&mode=itemnquery&qlayer=fogli&qitem=FOGLIO_N&qstring=('[FOGLIO_N]'%20IN%20'10')
Thanks to all
Roger
Roger Boily wrote:
> Hi Stephen,
> Thanks for answering. Yes, I've escaped the spaces with %20 and tried
> to escape ' with %27 too.
> No way to make it run. I had it working for one year with MapServer
> 3.6 (both Linux and Win) and it works
> fine also with the qstring modifications on MapServer 4.0 for
Windows,
> but I can't figure out where is
> the problem with Linux (tested on two servers). Even the simple
> &qstring=('[PART_N]' IN '556') does not
> work. It works fine with &qitem=PART_N&qstring=556 .
> To help you in helping me :-), I have made an example on my local
> testing server:
> The first url works properly and the second one fails.
http://213.45.107.14/cgi-bin/mapserv?&map=/var/www/html/sittel/procida/urbis.map&layer=fogli&mapext=shapes&mode=itemnquery&qlayer=fogli&qitem=FOGLIO_N&qstring=10
http://213.45.107.14/cgi-bin/mapserv?&map=/var/www/html/sittel/procida/urbis.map&layer=fogli&mapext=shapes&mode=itemnquery&qlayer=fogli&qstring=([FOGLIO_N]'%20IN%20'10')
> I attach also the map file.
> I need the second one to work because I have to query two fields at
once.
> ex: FOGLIO_N = 10 AND PART_N = 254
> Thanks in advance, Roger
> MAP FILE: urbis.map
> NAME urbis
> STATUS ON
> SIZE 650 400
> EXTENT 475.66 2404.5 5974.34 6239.61
> UNITS meters
> SHAPEPATH "data"
> IMAGETYPE PNG
> IMAGECOLOR 153 153 153
> TRANSPARENT ON
> FONTSET "/var/www/html/sittel/procida/font/fonts.txt"
> WEB
> TEMPLATE header_1024.html
> IMAGEPATH '/var/www/html/tmp/'
> IMAGEURL '/tmp/'
> MINSCALE 100
> END #WEB
> QUERYMAP
> STATUS ON
> STYLE HILITE
> COLOR 255 255 0 # highlight color is yellow
> END
> ###### LAYER C A T A S T O ###########
> LAYER
> NAME 'catasto'
> TYPE Polygon
> STATUS ON
> DATA 'lotti'
> # TEMPLATE index_basso.phtml
> LABELITEM 'PART_N'
> MAXSCALE 25000
> CLASS
> Name 'catasto'
> LABEL
> TYPE TRUETYPE
> FONT time
> BUFFER 3
> COLOR 255 0 0
> POSITION CC
> SIZE 8
> END
> OUTLINECOLOR 100 255 000
> END # CLASS
> END # LAYER
> ###### LAYER F O G L I ########
> LAYER
> NAME "fogli"
> TYPE Polygon
> STATUS ON
> DATA "fogli"
> LABELITEM 'FOGLIO_N'
> CLASS
> Name 'foglio'
> TEXT (Foglio [FOGLIO_N])
> LABEL
> TYPE TRUETYPE
> FONT time
> BUFFER 1
> COLOR 0 0 0
> POSITION auto
> SIZE 10
> END
> OUTLINECOLOR 255 255 255
> END # CLASS
> END # LAYER fogli
> END
> End of map file
> Steve Lime wrote:
>>Are you escaping the value ('[PART_N]' IN '556,557' AND '[ID_N]' IN
>>'24') properly? Spaces aren't allowed and should be replaced with
either
>>a + or a %20. We should still track down the source of the error
though,
>>error 500's are never good.
>>Steve
>>Stephen Lime
>>Data & Applications Manager
>>Minnesota DNR
>>500 Lafayette Road
>>St. Paul, MN 55155
>>651-297-2937
>>>>>Roger Boily <boily at bsw.org> 2/3/2004 6:33:11 AM >>>
>>Hi,
>>On a cgi url I've tried to query on multiple fields with this:
>>NB: for easy reading space and " are normals but I used %20(space)
and
>>%27(')
>>&qstring=('[PART_N]' IN '556,557' AND '[ID_N]' IN '24')
>>it works perfectly on windows Mapserver 4.0.1
>>But I receive error 500 from Apache on linux: (Premature end of
script
>>headers: mapserv)
>>&qitem=PART_N&qstring=556 works fine on linux
>>but I receive the same error with:
>>Is there anyone who has any idea?
>>Is there a way to make multiple fileds query with qitem and qstring?
>>Thanks a lot
>>Roger
>>_______________________________________________
>>Mapserver-users mailing list
>>Mapserver-users at lists.gis.umn.edu
>>http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
