[Mapserver-users] Reprojection of shape file.
Pericles Nacionales
nacional at cbs.umn.edu
Thu Feb 5 17:03:30 EST 2004
Why don't you run ogrinfo on your data and see if the extents are actually
in latlong? Or if the shapefiles include a .PRJ extension, open it up and
see what the projection is. If they are in latlong, run cs2cs to
reproject the extents to the stateplane cs.
-Perry
On Thu, 5 Feb 2004, Jason M. Nielsen wrote:
> I have been assured the provided shape file is in WGS84 Lat Long. I want to keep
> the original data in this and display it in NAD83 Stateplane Utah Central (US
> Foot). Below are what I think the relevant map file chunks are. Basically when
> displaying that layer I just get a blank image as if its way out of the
> coordinates. Anyone see whats wrong?
> NAME SLC
> STATUS ON
> SIZE 600 400
> #EXTENT 1400000.0 7000000.0 1900000.0 7500000.0
> EXTENT 1468185.000 7329845.000 1563785.000 7473605.000
> UNITS FEET
> SHAPEPATH "data"
> IMAGECOLOR 0 0 0
> IMAGETYPE PNG24
> PROJECTION
> "init=epsg:2281"
> END
> LAYER
> NAME slc2002photos
> TYPE POLYGON
> STATUS OFF
> DATA slc2002photos
> PROJECTION
> "init=epsg:4326"
> END
> CLASS
> NAME "SLC 2002 Photos"
> SYMBOL "circle"
> SIZE 2
> COLOR 255 255 0
> TEMPLATE slc2002photos.html
> END
> HEADER header.html
> FOOTER footer.html
> END
> I thought perhaps Id try to convert the file manually and see what it looked
> like. Im apparently doing something wrong here too.
> [root at vad3rZIM data]# ogr2ogr -f "ESRI Shapefile" -s_srs epsg:4326 -t_srs
> epsg:2281 trans slc2002photos.shp
> ERROR 1: latitude or longitude exceeded limits
> Failed to transform feature 0.
> ERROR 1: Terminating translation prematurely after failed
> translation of layer slc2002photos
> Was I given bogus data?
> Thanks, Jason.
> This mail sent through IMP: http://horde.org/imp/
> Mapserver-users mailing list
> Mapserver-users at lists.gis.umn.edu
> http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
