[Mapserver-users] shape file reprojection on the fly.
Amit S BEHERE
abehere at cs.ucsd.edu
Thu Feb 5 17:31:06 EST 2004
I have an additional question on this one. I understand that the
projection in the MAP object is the output projection. However say I have
a map with a few layers and I want to do a OGIS get map request on one or
more
layer(s). So unless I do the request in the same SRS as the one defined on
the map object I am not going to get useful stuff back. Is that right ?
So whats the use of the SRS field in the OGIS Getmap request ?
Is there any way I can send th OGIS getmap request with an srs thats
different from the one specified on the map object and have it return the
correct image.
-Amit
Amit Behere.
UCSD.
"Technology doesn't make your life more difficult or easy, it just changes
the rules"......Vishwanathan Anand
On Wed, 4 Feb 2004, Pericles S. Nacionales wrote:
> Correct. The projection definition on the main MAP object is your
> output projection and the projection definition in your LAYER object is
> whatever projection your data is in. See
> http://hypnos.cbs.umn.edu/projects/tutorial/example1-6.html for an
> example.
> -Perry
> On Wed, 2004-02-04 at 16:30, Jason M. Nielsen wrote:
> > To reproject shape files on the fly can you simply define a projection for the
> > main portion of your map and then also provide one in the definition of a layer?
> > Resulting in the proj in the layer def being transformed to the one in the main
> > part of the map file.
> > Someone beat me with a clue stick if I am off in left field on this.
> > This mail sent through IMP: http://horde.org/imp/
> > Mapserver-users mailing list
> > Mapserver-users at lists.gis.umn.edu
> > http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
> "He's no geek.His tan's too good." -Benjamin Choate
