[Mapserver-users] Virtual Spatial Data
we wei
mapgisnewbies at yahoo.com
Fri Feb 6 00:06:20 EST 2004
--0-1805737163-1076043980=:1305
Content-Type: text/plain; charset=us-ascii
Hi list,
I am working on a problem in connecting ODBC to postgresql from mapserver. I am using the suggestion from wiki, but i have a question on the tip wiki provided though.
It mentioned that we need to configure the apache by
1.Enable mod_env
2.add lines like: setenv ORACLE_HOME /path/
3.restart apache
I am not quite sure about step 2. What is the variable ORACLE_HOME and the "path" refer to? In my case I am using Postgresql, so what should be the environment variable's name ? and what will be the path it is related to ? Will the path mean the folder has the postgresql driver installed or the folder that the postgresql installed ?
Thanks in advance!
Do you Yahoo!?
Yahoo! Finance: Get your refund fast by filing online
Content-Type: text/html; charset=us-ascii
<DIV>Hi list,</DIV>
<DIV> </DIV>
<DIV>I am working on a problem in connecting ODBC to postgresql from mapserver. I am using the suggestion from wiki, but i have a question on the tip wiki provided though. </DIV>
<DIV> </DIV>
<DIV>It mentioned that we need to configure the apache by </DIV>
<DIV>1.Enable mod_env <BR>2.add lines like: setenv ORACLE_HOME /path/ <BR>3.restart apache </DIV>
<DIV> </DIV>
<DIV>I am not quite sure about step 2. What is the variable ORACLE_HOME and the "path" refer to? In my case I am using Postgresql, so what should be the environment variable's name ? and what will be the path it is related to ? Will the path mean the folder has the postgresql driver installed or the folder that the postgresql installed ?</DIV>
<DIV> </DIV>
<DIV>Thanks in advance!</DIV>
<DIV> </DIV><p><hr SIZE=1>
Do you Yahoo!?<br>
Yahoo! Finance: <a href="http://us.rd.yahoo.com/evt=22055/*http://taxes.yahoo.com/filing.html">Get your refund fast by filing online</a>
--0-1805737163-1076043980=:1305--
