[Mapserver-users] shape file reprojection on the fly.
Daniel Morissette
dmorissette at dmsolutions.ca
Fri Feb 6 09:54:29 EST 2004
Frank Warmerdam wrote:
> I believe the wms_srs parameters in the mapfile metadata are just used to
> determine what SRS'es will be advertised as supported in the WMS
> capabilities
> document. As far as I know any coordinate system in the PROJ.4 epsg
> support
> file will work even if it wasn't explicitly listed in the wms_srs list for
> the server.
That's correct: the wms_srs is used only to build the capabilities, but
any projection code from PROJ4's 'epsg' file can be used in a GetMap
request.
Daniel
Daniel Morissette dmorissette at dmsolutions.ca
DM Solutions Group http://www.dmsolutions.ca/
