[Mapserver-users] units question
Dave Walton
mapserver at digger.net
Fri Feb 6 15:42:59 EST 2004
On Fri, 06 Feb 2004 12:00:04 -0600
mapserver-users-request at lists.gis.umn.edu wrote:
> I have a shapefile which ogrinfo describes as below. It displays quite
> nicely in MapServer. However, I have to use meters for EXTENT, and when
> I produce a GeoTIFF image, the coordinates are in meters. I would very
> much like to be able to specify EXTENT in decimal degrees, and have the
> coordinates in the GeoTIFF in decimal degrees. How can I set up
> MapServer to do this?
Ok, nevermind. Someone else's question here gave me the hint I needed to
answer this. Use "ogr2ogr -t_srs 'epsg:4326'" to transform the data to
lat/long, and everything works as I wanted.
Dave
Dave Walton dwalton at acm.org
