[Mapserver-users] wms and projections
David Fawcett
David.Fawcett at state.mn.us
Fri Feb 6 16:40:00 EST 2004
I am still not sure why the data displays as it does. Ed, did you ever
take a look at the data?
Amit, how was the shapefile generated? Was it done in ArcInfo/ArcView
or some other means?
David.
David J. Fawcett
MN Office of Environmental Assistance
>>> Amit S BEHERE <abehere at cs.ucsd.edu> 2/6/2004 1:37:43 PM >>>
Hi all,
This is an extension of the question I had posted previously regarding
seeing only one point on the map. I had taken example1-1.map from the
tutorial and modified it to display my shapefile. However I was seeing
only one tree when I should have been seeing a whole bunch. Thanks to
David I was able to fix that (I needed to set MINSCALE, athough I
don't
know why yet?) and could see the whole set of trees.
Now I have converted that mapfile to serve as a WMS service by adding
the
appropriate wms tags in the mapfile. I am getting the capabilites back
correctly. However when I use the OGIS GetMap request I again see just
one
tree.
http://pune/mapserver/mapserv.exe?map=/MSTutorial/testwms.map&request=getmap&version=1.1
However if I view the same file i.e testwms.map using the regular
mapserver interface i.e using the command
http://pune/mapserver/mapserv.exe?map=/MSTutorial/testwms.map&mode=map
I see the whole set again. So basically I see just one tree if I give
the
OGIS getmap url and a whole set of trees when I give the regular
mapserver url. Any one encountered similar problems or any idea why
this
is happening
Here is my map file
MAP
NAME demoservice
IMAGETYPE PNG
EXTENT 385538 3761010 391329 3764477
UNITS METERS
SIZE 600 600
SHAPEPATH "data"
IMAGECOLOR 255 255 255
PROJECTION
"init=epsg:26911"
END
WEB
IMAGEPATH "c:\itasca\tmp\"
IMAGEURL "/tmp/"
MINSCALE 50000 #with this enabled, produces image with all
points
#MAXSCALE 15500000 #see 'with_scale_restrictions.png'
METADATA
"wms_title" "WMS Demo Server"
"wms_onlineresource"
"http://pune/mapserver/mapserv.exe?map=/MSTutorial/testwms.map&"
"wms_srs" "epsg:26911"
END
END
SYMBOL
NAME 'circle'
TYPE ELLIPSE
POINTS 1 1 END
FILLED TRUE
END
LAYER
NAME trees
DATA vernon_trees
STATUS DEFAULT
TYPE POINT
LABELITEM "TREEID"
CLASS
COLOR 0 0 0
SYMBOL 'circle'
SIZE 6
END
PROJECTION
"init=epsg:26911"
END
METADATA
"wms_extent" "385538 3761010 391329 3764477"ho
END
END # layer ends here
END # end of map file/object
Amit Behere.
UCSD.
"Technology doesn't make your life more difficult or easy, it just
changes
the rules"......Vishwanathan Anand
Mapserver-users mailing list
Mapserver-users at lists.gis.umn.edu
http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
