[Mapserver-users] jBox error - classnotfoundexception
Richard Greenwood
rich at greenwoodmap.com
Mon Feb 9 13:35:24 EST 2004
Beth Fucile wrote:
> I have installed the jbox applet and followed the instructions in the HOWTO
> document. I tried to implement this with an existing map file, but as a
> result the map is not loading, and instead I get the error message:
> java.lang.ClassNotFoundException: jBox.class
> My form contains the applet reference as:
> <applet
> codebase="/java/jBox"
> archive="jBox.jar"
> code="jBox.class"
> width=[mapwidth] height=[mapheight]
> name="jBox"
> MAYSCRIPT>
> <param name="image" value="http://[host][img]">
> </applet>
> I've copied the jBox.jar file under my root web tree as referenced above --
> java/jBox/jBox.jar
> What could be the cause of this error?
Everything looks good to me. A couple things you could try:
1. We just started with the .jar files, so I am naturally suspicious
that the problem may be there. So as an alternative, put the jBox.class
and evalThread.class files into java/jBox/ directory instead of
jBox.jar. And remove the archive="jBox.jar" line.
2. Is java/jBox/ accessible from your browser? I quick test would be to
but some file in java/jBox/ and then check that it displays in your
browser. For example, if you put a file named "test.html" in java/jBox/,
then from your browser go to http://localhost/java/jBox/test.html and
verify that you can see it.
Rich
Richard Greenwood
www.greenwoodmap.com
