[Mapserver-users] How to use mapserver to cascade arcims wms services
Larry Nolan
larrynolan at gov.nl.ca
Tue Feb 10 10:23:53 PST 2004
Thanks Bart,
It turns out that my problem is in my projection specification. If I put an espg:26721 it works fine but is projected incorrect.
I'm trying to use a Transverse Mercator projection centered on 59.5 degrees west with a false easting of 1000000 and a false northing of 0 in NAD 27
But for some reason mapserver or arcims reports an error.
The projection string in the arcims axl file is:
<FEATURECOORDSYS string='PROJCS["NF_GNL1",GEOGCS["GCS_North_American_1927",DATUM["D_North_American_1927",SPHEROID["Clarke_1866",6378206.4,294.9786982]],PRIMEM["Greenwich",0.0],UNIT["Degree",0.0174532925199433]],PROJECTION["Transverse_Mercator"],PARAMETER["False_Easting",1000000.0],PARAMETER["False_Northing",0.0],PARAMETER["Central_Meridian",-59.5],PARAMETER["Scale_Factor",0.998],PARAMETER["Latitude_Of_Origin",0.0],UNIT["Meter",1.0]]' />
In Mapserver I am using:
Projection
"proj=tmerc"
"lat_0=0.0"
"lon_0=-59.5"
"k=0.998"
"x_0=1000000.0"
"y_0=0.0"
"ellps=clrk66"
"units=m"
"no_defs"
End
Thanks.
Larry Nolan
GIS and Geoscience Data Management
Geological Survey of Newfoundland and Labrador
Department of Mines and Energy
http://gis.geosurv.gov.nf.ca
telephone 709-729-2168
fax 709-729-4270
>>> Bart van den Eijnden <bartvde at xs4all.nl> 02/07/04 01:24PM >>>
Hi Larry,
first of all I think your wms_name is invalid, because it contains a
space. The wms_name is used to perform the WMS request. Secondly, you
should use 1 wms_format instead of 2 formats separated by commas (does
your ArcIMS server have a GIF license, if not use image/png).
Here I have a working example (BTW I am using the ESRI WMS connector 0.0.6
instead of the standard version delivered with ArcIMS 4):
LAYER
CONNECTION
"http://myserver/ogcwms/servlet/com.esri.ogc.wms.WMSServlet?servicename=top50vector&SERVICE=WMS&VERSION=1.1.0&LAYERS=t50_vlakken_region&QUERY_LAYERS=t50_vlakken_region&FORMAT=image/png&transparent=true"
CONNECTIONTYPE WMS
METADATA
"wms_srs" "EPSG:28992 EPSG:4326"
"wms_onlineresource" "http://myserver/ogcwms/servlet/com.esri.ogc.wms.WMSServlet?servicename=top50vector&"
"wms_stylelist" ""
"wms_name" "top50vector_t50_vlakken_region"
"wms_title" "top 50 vector"
"wms_style_default_title" ""
"wms_style_default_legendurl" "0 0 "
"wms_server_version" "1.1.0"
"wms_formatlist" "image/jpeg,image/png"
"wms_format" "image/png"
"wms_boundingbox" "EPSG:28992 0 288007.5 288009 624000"
"wms_style" "default"
"wms_latlonboundingbox" "2.68506 49.54247 7.75847 54.61588"
END
NAME "top50vector_t50_vlakken_region"
PROJECTION
"init=epsg:28992"
END
SIZEUNITS PIXELS
STATUS ON
DUMP TRUE
MINSCALE 0
MAXSCALE 50000
TEMPLATE "blank.html"
TOLERANCE 0
TOLERANCEUNITS PIXELS
TYPE RASTER
UNITS METERS
END
Best regards,
Bart
On Fri, 06 Feb 2004 16:47:18 -0330, Larry Nolan <larrynolan at gov.nl.ca>
wrote:
> I have a group of geological surveys which have arcims web mapping
> servers with tons of geological information. I would like to use
> mapserver to act as a one stop connection to each of those servers in a
> client. I have mapserver 4.0 working fine serving ogc wms map services.
> Does anyone have the syntax to connect to an esri arcims service which
> has the wms connector turned on.
> I get a a general service exception when I try to connect to this layer.
> LAYER
> NAME "NAD27LandBase"
> TYPE RASTER
> STATUS ON
> CONNECTION
> "http://gis.geosurv.gov.nf.ca/servlet/com.esri.wms.Esrimap?servicename=NAD27_Basemap"
> CONNECTIONTYPE WMS
> METADATA
> "wms_name" "Base Map"
> "wms_formatlist" "image/gif,image/png,image/jpeg,image/wbmp"
> "wms_format" "image/gif,image/png"
> END
> PROJECTION
> "proj=tmerc"
> "lat_0=0.0"
> "lon_0=-59.5"
> "k=0.998"
> "x_0=0.0"
> "y_0=1000000.0"
> "ellps=clrk66"
> "units=m"
> "no_defs"
> END
> END
> thanks
> Larry Nolan
> Mapserver-users mailing list
> Mapserver-users at lists.gis.umn.edu
> http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
More information about the MapServer-users
