[Mapserver-users] new to mapserver - installation help
Gerry Creager N5JXS
gerry.creager at tamu.edu
Tue Feb 10 22:47:15 EST 2004
That's actually a feature. A Security Feature. You really don't want
cgi scripts/programs running as root lest there occur a problem and the
resultant error drop someone into a root shell.
Setting your file ownership to that of the webserver is a bit safer.
gerry
Michael Darweesh wrote:
> Double-check the permissions and file information on your mapserver
> executable. the Redhat http doesn't like executing cgi where the
> executable is owned by root. Though, I can't be sure that's your
> installation's problem without more information. What does your
> /var/www/http/error_log say when you try to run as cgi?
> -Mike
> arun at activeengineer.com wrote:
>> I am trying to install on Redhat. If I compile with GD and Freetype,
>> it tests fine from web browser. But thn if I add proj or gdal, it
>> compiles fine and tests of from the command line but errors out (
>> Internal Server error 500 ) from the web browser. File permissions are
>> identical in both cases. CAn any one throw some light please?
>> Arun
>> Mapserver-users mailing list
>> Mapserver-users at lists.gis.umn.edu
>> http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
Gerry Creager -- gerry.creager at tamu.edu
Network Engineering -- AATLT, Texas A&M University
Cell: 979.229.5301 Office: 979.458.4020 FAX: 979.847.8578
Page: 979.228.0173
Office: 903A Eller Bldg, TAMU, College Station, TX 77843
