[Mapserver-users] Re: Using Mapserver & GDAL to find elevation
Frank Warmerdam
warmerdam at pobox.com
Wed Feb 11 12:34:32 PST 2004
Arthur, John wrote:
> Thanks Frank. Is there any other ideas outside of mapserver, maybe?
John,
Well, you could use GDAL more directly. What flavour of MapScript are you
using? Perl? Python? PHP? There are Python bindings for GDAL and I
think there are PHP bindings as well. If you are using one of these it
should be possible to callout to GDAL directly to get the values. This
would be slightly ackward, but doable. If you are using perl, things
might be more challenging. Perhaps then the best would be to write a small
external C++ utility to fetch the values.
Best regards,
and watch the world go round - Rush | Geospatial Programmer for Rent
More information about the MapServer-users
