[Mapserver-users] Displaying WFS data from a GeoServer/OracleSpatial server
Bart van den Eijnden bartvde at xs4all.nl
Thu Feb 12 14:46:06 PST 2004
Hi Jeff,
if I use the following MAP file I get the correct GML in my temp directory
and an Image. Note that I use a MAXFEATURES to prevent getting a timeout.
BTW Try removing your METADATA and see if that works, or fill in the
complete metadata (including at least wfs_service, wfs_typename).
NAME "sample client"
STATUS ON
SIZE 400 300
#SYMBOLSET "../etc/symbols.sym"
EXTENT 76.1 -69.4 76.4 -69.2
UNITS METERS
SHAPEPATH "../data"
IMAGECOLOR 255 255 255
#FONTSET "../etc/fonts.txt"
IMAGETYPE PNG24
WEB
   IMAGEPATH "/ms4w/tmp/ms_tmp/"
   IMAGEURL "/ms_tmp/"
END
PROJECTION
   "init=epsg:4326"
END
LAYER
   NAME popplace
   CONNECTIONTYPE WFS
   CONNECTION
"http://aadc-maps.aad.gov.au/geoserver/wfs?VERSION=1.0.0&REQUEST=GetFeature&TYPENAME=topp:ICEBERG_PY&MAXFEATURES=100"
   TYPE POLYGON
   STATUS ON
   PROJECTION
     "init=epsg:4326"
   END
   CLASS
     NAME "test"
     COLOR 255 0 0
   END
END
END
Best regards,
Bart
On Thu, 12 Feb 2004 14:58:25 -0500 (EST), Jeff McKenna
<jmckenna at dmsolutions.ca> wrote:
> (with a subject line, sorry)
> Hello,
> I am trying to view a WFS layer in MapServer from a server that is
> publishing their data
> using GeoServer (and they are storing their data in Oracle).  When I try
> their GetFeature
> request in a browser valid GML is returned
> (http://aadc-maps.aad.gov.au/geoserver/wfs?VERSION=1.0.0&REQUEST=GetFeature&TYPENAME=topp:ICEBERG_PY).
>  I have verified that the GML is valid with the ogrinfo utility, as well
> as converting the
> GML to a shapefile using the OGR2OGR utility...it looks good.  But when
> I try to access
> the layer with MapServer I get a lovely MapServer error:
> [MapServer Error]: msWFSLayerWhichShapes(): WFS request produced
> unexpected output (junk?)
> for layer aad_wfs
> In my IMAGEPATH directory the GML file that is produced looks like this:
> <?xml version="1.0" ?>
> <ServiceExceptionReport
>    version="1.2.0"
>    xmlns="http://www.opengis.net/ogc"
>    xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance"
>    xsi:schemaLocation="http://www.opengis.net/ogc
> http://localhost:8080/geoserver/data/capabilities/wfs/1.0.0/OGC-exception.xsd">
>    <ServiceException>
>       problem with FeatureResults:
> org.geotools.data.DataSourceException: Could not count
> 	at
> org.geotools.data.jdbc.JDBCFeatureSource.count(JDBCFeatureSource.java:402)
> 	at
> org.geotools.data.jdbc.JDBCFeatureSource$1.getCount(JDBCFeatureSource.java:218)
> 	at
> org.vfny.geoserver.responses.wfs.FeatureResponse.execute(FeatureResponse.java:307)
> 	at
> org.vfny.geoserver.responses.wfs.FeatureResponse.execute(FeatureResponse.java:193)
> 	at
> org.vfny.geoserver.servlets.AbstractService.doService(AbstractService.java:295)
> 	at
> org.vfny.geoserver.servlets.AbstractService.doGet(AbstractService.java:202)
> 	at javax.servlet.http.HttpServlet.service(HttpServlet.java:740)
> 	at javax.servlet.http.HttpServlet.service(HttpServlet.java:853)
> 	at
> org.vfny.geoserver.servlets.wfs.WfsDispatcher.doResponse(WfsDispatcher.java:172)
> 	at
> org.vfny.geoserver.servlets.wfs.WfsDispatcher.doGet(WfsDispatcher.java:123)
> 	at jrun.servlet.ServletInvoker.invoke(ServletInvoker.java:91)
> 	at jrun.servlet.JRunInvokerChain.invokeNext(JRunInvokerChain.java:42)
> 	at
> jrun.servlet.JRunRequestDispatcher.invoke(JRunRequestDispatcher.java:252)
> 	at
> jrun.servlet.ServletEngineService.dispatch(ServletEngineService.java:527)
> 	at jrun.servlet.http.WebService.invokeRunnable(WebService.java:168)
> 	at
> jrunx.scheduler.ThreadPool$ThreadThrottle.invokeRunnable(ThreadPool.java:451)
> 	at jrunx.scheduler.WorkerThread.run(WorkerThread.java:66)
> Caused by: java.sql.SQLException: ORA-00921: unexpected end of SQL
> command
> 	at oracle.jdbc.dbaccess.DBError.throwSqlException(DBError.java:134)
> 	at oracle.jdbc.ttc7.TTIoer.processError(TTIoer.java:289)
> 	at oracle.jdbc.ttc7.Oall7.receive(Oall7.java:579)
> 	at oracle.jdbc.ttc7.TTC7Protocol.doOall7(TTC7Protocol.java:1894)
> 	at
> oracle.jdbc.ttc7.TTC7Protocol.parseExecuteDescribe(TTC7Protocol.java:831)
> 	at
> oracle.jdbc.driver.OracleStatement.doExecuteQuery(OracleStatement.java:2496)
> 	at
> oracle.jdbc.driver.OracleStatement.doExecuteWithTimeout(OracleStatement.java:2840)
> 	at
> oracle.jdbc.driver.OracleStatement.executeQuery(OracleStatement.java:623)
> 	at
> org.geotools.data.jdbc.JDBCFeatureSource.count(JDBCFeatureSource.java:391)
> 	... 18 more
>    </ServiceException>
> </ServiceExceptionReport>
> The mapfile that I'm using is as follows:
> NAME AAD_WFS
> STATUS ON
> SIZE 400 300
> SYMBOLSET ./etc/symbols.sym
> EXTENT 60 -90 160 0
> UNITS DD
> #SHAPEPATH "C:/GCRC/data/antarctica/scale0/st17_20"
> FONTSET ./etc/fonts.txt
> WEB
>   IMAGEPATH "c:/tmp/ms_tmp/"
>   IMAGEURL "c:/ms_tmp/"
>   METADATA
>   END
>   LOG "c:/GCRC/www/add-demo/htdocs/ms_error.txt"
> END
> PROJECTION
>   "init=epsg:4326"
> END
> LAYER
>     NAME "aad_wfs"
>     TYPE POLYGON
>     CONNECTIONTYPE WFS
>     CONNECTION
> "http://aadc-maps.aad.gov.au/geoserver/wfs?VERSION=1.0.0&REQUEST=GetFeature&TYPENAME=topp:ICEBERG_PY"
>     PROJECTION
>       "init=epsg:8307"
>     END
>     METADATA
>       "wfs_connectiontimeout" "60"
>       "wfs_latlonboundingbox" "60 -90 160 0"
>     END
>     STATUS ON
>     DEBUG TRUE
>     CLASS
>       NAME "test"
>       COLOR 255 0 0
>     END
> END
> The WFS server in question is actually the Australian Antarctic Division
> (AAD), and we are
> trying to make their data available to other partners around the world.
> Is it something
> on their side that is causing MapServer to blow up??
> From a GetCapabilities request we can see that the data is in 8307 EPSG,
> which is not
> included in the standard EPSG file....and I think that 8307 is the same
> as generic
> lat/long....so I added an 8307 code in my EPSG file with the same params
> as 4326 (is this
> the problem???).
> More questions: from comparing the GML returned in the browser with
> other valid GML that
> MapServer CAN display we've noticed that the AAD server GML states
> <gml:Box
> srsName="http://www.opengis.net/gml/srs/epsg.xml#8307"> whereas others
> say <gml:Box
> srsName="EPSG:9810">...is MapServer having a problem with that URL????
> Any help is greatly appreciated.
> jeff
> Jeff McKenna
> Research Assistant
> Geomatics and Cartographic Research Centre
> Carleton University
> Ottawa, ON
> Canada
> Mapserver-users mailing list
> Mapserver-users at lists.gis.umn.edu
> http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
More information about the MapServer-users mailing list
