[Mapserver-users] Max number of layers craps out at about 295
Stephen Clark
stephen.clark at focus.ca
Fri Feb 13 12:04:58 EST 2004
Frank and others,
I see in the 4.0.1 release that maxcolors is set to 256 and maxclasses is
set to 250.
#define MS_MAXCOLORS 256
#define MS_MAXCLASSES 250
So can I make the assumption that to increase the number of layers I DO NOT
NEED to touch these
#define's?
thanks,
Stephen
----- Original Message -----
To: "Stephen Clark" <stephen.clark at focus.ca>
Cc: <mapserver-users at lists.gis.umn.edu>
Sent: Friday, February 13, 2004 7:44 AM
Subject: Re: [Mapserver-users] Max number of layers craps out at about 295
> Stephen Clark wrote:
> > Pericles,
> > I chose the number 700 for each of the following :
> > #define MS_MAXCOLORS 700
> > #define MS_MAXCLASSES 700
> > #define MS_MAXLAYERS 700
> > because I thought that each LAYER needed the same number of CLASSES and
> > COLORS.
> > So can I assume that if I have about 3 classes per layer then I can use
the
> > following:
> > #define MS_MAXCOLORS 128
> > #define MS_MAXCLASSES 128
> > or perhaps a number less than 128?
> > I will try out this option and recompile MS with the above specs.
> Stephen,
> MAXLAYERS and MAXCOLORS should be pretty configurable. But I would like
> to discourage using values for MAXCOLORS other than 256 unless you have
> looked through the implications. Somethings are just #defined macros out
> of habit ... not because they should be fiddled with.
> Best regards,
> I set the clouds in motion - turn up | Frank Warmerdam,
warmerdam at pobox.com
> light and sound - activate the windows | http://pobox.com/~warmerdam
> and watch the world go round - Rush | Geospatial Programmer for Rent
