[Mapserver-users] Question - EROS NED service
    bartvde at xs4all.nl
    Fri Feb 13 09:33:59 PST 2004
as long as the ESRI's WMS connector is used on the ArcIMS service you
should be able to use it in Mapserver (as a cascading WMS) as well as in
PHP/Mapscript.
If there is no WMS connector (i.e. interface) on the ArcIMS service, then
you cannot use it with Mapserver.
Best regards,
Bart
> I was wondering if Mapserver is able to support ArcIMS services?  I am
> interested in using the EROS NED service which requires me to connect to
> 'http://gisdata.usgs.net'.  I was told I need to use arcMap, it would be
> wonderful if I could use Mapserver as I like what I see so far.
> Thank you,
> -brude
> fsbrc at uaf.edu
> Mapserver-users mailing list
> Mapserver-users at lists.gis.umn.edu
> http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
More information about the MapServer-users
