[Mapserver-users] Annotation setExpression() problem
Rene Teniere
TENIERER at gov.ns.ca
Mon Feb 16 12:25:36 EST 2004
Hi all,
Wondering if someone can help me here. I am creating an annotation
layer with a dynamic expression to label only what I want each time.
Problem is that I cannot set the expression through mapscript. It works
fine hard-coded in the mapfile, but it has to be done through php. The
expression would look like: /1234|2345|3456/ or /1234/ That is
represented in the $sExp variable in the code below. At first I set up
the mapfile annotation layer without an expression then used
$class->setExpression($sExp); to set the expression. That did not work,
even though the variable contents worked in the mapfile with the desired
results.
Next, I got rid of the annotation layer in the map file and decided to
create it through php/mapscript. The end results showed up with no
annotation at all. The code for the layer creation is below, and I have
no idea why it will not work. Anyone have any ideas?
Rene
<?php
$map_path = "C:/chameleon11a/websites/wap/";
$map = ms_newMapObj($map_path."sketch.map");
$map->setExtent($minX-10, $minY-10, $maxX+10, $maxY+10);
$image = $map->draw();
$wap = $map->getLayerByName("WAP");
$shapes = ms_newLayerObj($map, $wap);
$shapes->set("name","Shapes");
$shapes->set("data","");
//Create the annotation layer
$anno = ms_newLayerObj($map);
$anno->set("name","annolayer");
$anno->set("maxscale",500000);
$anno->set("status",MS_ON);
$anno->set("data","D:\gis_data\wap_2002\all");
$anno->set("type",MS_LAYER_ANNOTATION);
$anno->set("labelitem","ID");
$anno->set("classitem","ID");
$class = ms_newClassObj($anno);
$class->set("name","annoclass");
$class->set("status",MS_ON);
$class->label->type->MS_BITMAP;
$class->label->size->MS_MEDIUM;
$class->label->position->MS_CC;
$class->label->color->setRGB(255,0,0);
//Create Annotation Expression
$sExp = "/".$nID[0];
for($k=0; $k<=$nCOUNT; $k=$k+1)
if($k>0)
$sExp = $sExp."|".$nID[$k];
$sExp = $sExp."/";
//$expression = $class->getExpression();
//error_log("Before:".$expression);
//error_log("After:".$expression);
$shapes_class = ms_newClassObj($shapes);
$wap->open();
for($j=0; $j<=$nCOUNT; $j=$j+1)
$nShape[$j] = $wap->getShape(-1, $nIndex[$j]);
$nShape[$j]->draw($map, $shapes, $image);
$wap->close();
$scalebar = $map->drawScaleBar();
$image_url = $image->saveWebImage();
$scalebar_url = $scalebar->saveWebImage();
