[Mapserver-users] OGR not found in system libs...
Daniel Morissette
dmorissette at dmsolutions.ca
Wed Feb 18 12:36:32 EST 2004
Ray Ward wrote:
> Thanks for your reply Daniel, yes I am using the latest GDAL from cvs. I
> tried this morning but it seems your link is down, so I downloaded the last
> nightly build of mapserver and I am still getting an OGR error (output of
> that configure provided below). Wondering if this is still a configure
> script error?, maybe you could re-post your fix, or send me instructions on
> what needs to be modified?...or perhaps this really is an OGR problem, if so
> do you know a better way to test for the proper installation of GDAL/OGR?
> Thanks for any help you can provide...
> checking for pj_latlong_from_proj in -lproj... yes
> using PROJ.4 from /usr/local.
> configure: checking whether we should include thread safe support......
> thread safe support disabled.
> configure: checking whether we should include ESRI SDE support......
> ESRI SDE support not requested.
> configure: checking whether we should compile in MPATROL support......
> MPATROL support not requested.
> configure: checking whether we should include OGR support......
> checking for OGRRegisterAll in -lgdal... no
> checking for OGRRegisterAll in -lgdal.1.1... no
> configure: WARNING: OGR not available.
> checking if GDAL support requested... yes, user supplied gdal-config
> (/usr/local/bin/gdal-config)
> checking checking ms JPEG output... no we, have GDAL available.
> configure: checking whether we should include TIFF support......
> using libtiff from -L/usr/local/lib64 -ltiff.
> checking if PostGIS support requested... yes, user supplied pg_config
> checking if MyGIS support requested... no
> checking if OracleSpatial support requested... no
> checking if MING/Flash support requested... yes, user supplied MING
> directory
> ./configure: -lming: command not found
> configure: checking whether we should include WMS Server support......
> OGC WMS compatibility enabled (-DUSE_WMS_SVR).
> configure: checking whether we should include WFS Server support......
> configure: error: OGC WFS Server support cannot be enabled: missing OGR
> which is required).
Ray,
(Please reply via the list since others may be able to help solve your
problem, or may be interested in the solution to your problem.)
The link http://www2.dmsolutions.ca/tmp/ms-401-configure.tar.gz is up,
or at least it works for me.
Looking at the configure output above it seems that you have a version
that includes the right fix.
BTW, the following error...
suggests that either libgdal.so in not compiled with OGR (it should be
by default), or you didn't 'make install' to install GDAL, or there is
no libgdal.so in /usr/local/lib ... can you check that you have
libgdal.so somewhere and that OGR is enabled?
Oh wait... I see that libtiff was found in -L/usr/local/lib64 ... are
you running a 64 bits linux box? Maybe there is something specific to
detecting GDAL/OGR on 64 bits Linux systems that's not properly handled yet.
Daniel
Daniel Morissette dmorissette at dmsolutions.ca
DM Solutions Group http://www.dmsolutions.ca/
