[Mapserver-users] Problem with WFS
Bart van den Eijnden
bartvde at xs4all.nl
Thu Feb 19 14:34:18 EST 2004
I don't think ESRI will address this soon.
The latest GIS Monitor sheds some light on this issue:
http://www.gismonitor.com/news/newsletter/archive/021904.php#ArcGIS
excerpt from the GIS Monitor:
"There is a curious statement on page 1 of the User Guide which I
suspected was a typo, but which ESRI states is not: "The OGC
Interoperability Add-on enables you to add feature services from ESRI Web
Feature Servicesâ¦" An ESRI representative reports, "ESRI WFS is based on
the profile for GML that ESRI is currently using. The Add-on will also
support any WFS that uses the
same profile of GML as ESRI's WFS."
Best regards,
Bart
On Wed, 18 Feb 2004 16:16:24 -0500, Van Ulden, Joost
<jvanulde at nrcan.gc.ca> wrote:Hi,
> We also have the same problem. When we check with an HTTP Sniffer,
> ArcMap
> never makes the GetFeature Request. Not sure what is happening. If you
> try
> to load MapServer GML into ArcMap you also get an error. We have come to
> the same conclusion as Bart. Hopefully, ESRI will address this soon!
> Cheers,
> Joost van Ulden
> Programmer/Analyst
> Natural Resources Canada / Ressources naturelles Canada
> Geological Survey of Canada / Commission geologique du Canada
> 101 - 605 Robson Street / 101 - 605 rue Robson
> Vancouver, B.C. / Vancouver (C.-B.)
> V6B 5J3
> Office/Bureau: 604.666.7525
> fax/telecopieur: 604.666.1124
>> -----Original Message-----
>> From: Bart van den Eijnden [mailto:bartvde at xs4all.nl]
>> Sent: Wednesday, February 18, 2004 10:00 AM
>> To: Florian Jurgeit; mapserver-users at lists.gis.umn.edu
>> Subject: Re: [Mapserver-users] Problem with WFS
>> Hi,
>> I've encountered the same problem.
>> My guess is that the ESRI GML parser expects the GML to be
>> similar to what
>> the ESRI WFS produces, and this is a bit different from the
>> Mapserver GML.
>> So my guess is that the ESRI GML parser is a bit too tight.
>> Some differences are:
>> -Mapserver uses <wfs:FeatureCollection> as the root element,
>> ESRI uses
>> <Features>
>> -Mapserver uses by default MS_GEOMETRY for the "spatial attribute"
>> (although it can be changed), ESRI uses _SHAPE_
>> You could try using _SHAPE_ instead of MS_GEOMETRY in Mapserver WFS.
>> Anyway, it still is a guess because I don't know the ESRI internals.
>> BTW: is this the maximum debug/log level you can get in ArcMap?
>> Best regards,
>> Bart
>> On Wed, 18 Feb 2004 14:27:17 +0100, Florian Jurgeit
>> <Florian.Jurgeit at uibk.ac.at> wrote:
>> > When trying to load WFS data in ArcMAP the error "Unable to
>> parse WFS
>> > data" occures.
>> > The WFS service is done by an UMN MapServer - the Output
>> looks OK in
>> > the
>> > Browser.
>> > Getting the List of Layers works in ArcMAP - just opening
>> one does not
>> > work (pasring error - Why ?)
>> > Greatings from Austria,
>> > Flo
>> > The WFS-Code looks that way (in the Browser): (only frist
>> element ...)
>> > <?xml version="1.0" encoding="ISO-8859-15" ?>
>> > - <#> <wfs:FeatureCollection xmlns="*http://www.ttt.org/myns*"
>> > xmlns:myns="*http://www.ttt.org/myns*"
>> > xmlns:wfs="*http://www.opengis.net/wfs*"
>> > xmlns:gml="*http://www.opengis.net/gml*"
>> > xmlns:xsi="*http://www.w3.org/2001/XMLSchema-instance*"
>> > xsi:schemaLocation="*http://www.opengis.net/wfs
>> http://ogc.dmsolutions.ca/wfs/1.0.0/WFS-basic.xsd/wfs/1.0.0/WF
>> S-basic.xsd
>> http://XXX.XXXX.ac.at/cgi-bin/mapserv?map=/home/cXXXXXX/public
>> _html/ta_map/ta_wfs.map&SERVICE=WFS&VERSION=1.0.0&REQUEST=Desc
> ribeFeatureType&TYPENAME=g1gem*">
>> > - <#> <gml:boundedBy>
>> > - <#> <gml:Box srsName="*EPSG:32632*">
>> > <gml:coordinates>550953.125000,137001.765625
>> > 817651.250000,287281.500000</gml:coordinates>
>> > </gml:Box>
>> > </gml:boundedBy>
>> > - <#> <gml:featureMember>
>> > - <#> <g1gem>
>> > <COUNT>1</COUNT>
>> > <ID>120307</ID>
>> > <TYP>gem</TYP>
>> > <LEVEL>800</LEVEL>
>> > <GEM_NAME>Kötschach-Mauthen</GEM_NAME>
>> > - <#> <MS_GEOMETRY>
>> > <gml:coordinates>797267.125000,168217.484375
>> > 811924.625000,182463.218750</gml:coordinates>
>> > </gml:Box>
>> > </gml:boundedBy>
>> > - <#> <gml:Polygon srsName="*EPSG:32632*">
>> > - <#> <gml:outerBoundaryIs>
>> > - <#> <gml:LinearRing>
>> > <gml:coordinates>805507.500000,180764.437500
>> > 807767.625000,180515.187500 808255.562500,180119.078125
>> > 808718.125000,179930.078125 808993.125000,179923.187500
>> > 809386.562500,180023.078125 809839.187500,179958.812500
>> > 810139.062500,180029.484375 810649.250000,180029.546875
>> > 810483.500000,179581.343750 809828.750000,178621.031250
>> > 809631.500000,178581.078125 809388.187500,178248.906250
>> > 809160.187500,178202.250000 809046.500000,178246.109375
>> > 808988.875000,178182.781250 809021.375000,177865.812500
>> > 809233.875000,177592.843750 809185.687500,177430.812500
>> > 809116.500000,177394.921875 809127.000000,177295.265625
>> > 809048.812500,177276.921875 808989.250000,177120.265625
>> > 809022.750000,177021.875000 808947.875000,176925.531250
>> > 809001.312500,176483.406250 808917.750000,176053.781250
>> > 808629.937500,175764.265625 809191.812500,175409.312500
>> > 810011.125000,175166.765625 810812.125000,175129.703125
>> > 811762.062500,174990.578125 811677.187500,174365.406250
>> > 811725.875000,174173.625000 811602.625000,173317.781250
>> > 811385.687500,172742.484375 811319.312500,172709.750000
>> > 811163.062500,171524.312500 811316.937500,170842.125000
>> > 811693.187500,170398.718750 811430.000000,169716.625000
>> > 811924.625000,168801.953125 811668.187500,168722.312500
>> > 811340.750000,168766.875000 811159.187500,168480.953125
>> > 810874.187500,168458.562500 810442.750000,168403.250000
>> > 810246.750000,168243.109375 810013.312500,168217.875000
>> > 809697.500000,168395.343750 808889.250000,168217.484375
>> > 808531.625000,168358.187500 808449.062500,168511.015625
>> > 808121.812500,168774.453125 808086.312500,168663.718750
>> > 807707.437500,168799.984375 807069.437500,168517.265625
>> > 806679.187500,168775.859375 806478.312500,168772.593750
>> > 806170.062500,168638.468750 805965.250000,168632.125000
>> > 805896.312500,168453.750000 805452.812500,168404.218750
>> > 805027.875000,168590.343750 804813.437500,168491.406250
>> > 804581.500000,168658.359375 804380.500000,168619.312500
>> > 804361.375000,168771.343750 804123.875000,168745.015625
>> > 803944.812500,168928.156250 803608.062500,168841.109375
>> > 803239.375000,169012.812500 803045.375000,168936.406250
>> > 803004.437500,168809.546875 802791.500000,168789.718750
>> > 802769.187500,168613.250000 802635.312500,168510.640625
>> > 801560.437500,169092.500000 801428.437500,169323.406250
>> > 801040.625000,169349.796875 800246.312500,169140.734375
>> > 799805.625000,169241.640625 799401.000000,168972.437500
>> > 798614.375000,169096.406250 798130.000000,168846.343750
>> > 797938.437500,168859.109375 797944.437500,169402.171875
>> > 798106.125000,170196.890625 798086.625000,170423.343750
>> > 797781.750000,170990.890625 798162.062500,172057.250000
>> > 797911.312500,172078.515625 797862.500000,172273.281250
>> > 797678.625000,172553.828125 797680.625000,172790.468750
>> > 797839.812500,173412.656250 798014.187500,173449.328125
>> > 798392.562500,173677.640625 798659.187500,174277.687500
>> > 798746.875000,174578.187500 798699.312500,175641.031250
>> > 798913.062500,176346.421875 798780.375000,176844.265625
>> > 798668.187500,176861.140625 798678.437500,177093.234375
>> > 798586.625000,177212.468750 798635.437500,177345.453125
>> > 798581.437500,177434.687500 798495.125000,177435.953125
>> > 798431.687500,177550.734375 798233.062500,177553.812500
>> > 798018.500000,177445.765625 797876.562500,177602.312500
>> > 797789.812500,177831.078125 797742.437500,177980.812500
>> > 797938.562500,178386.531250 798041.937500,178475.421875
>> > 798189.000000,178480.531250 798339.437500,178642.171875
>> > 798415.187500,178941.031250 798315.000000,179121.937500
>> > 798374.000000,179251.484375 798137.250000,179728.546875
>> > 798173.750000,179865.875000 797999.625000,180060.750000
>> > 797885.187500,180355.125000 797684.000000,180567.546875
>> > 797619.687500,180552.984375 797571.187500,180905.125000
>> > 797507.625000,180912.640625 797408.687500,181125.687500
>> > 797353.500000,181126.656250 797345.437500,181236.468750
>> > 797267.125000,181257.203125 797899.312500,182006.718750
>> > 797853.125000,182463.218750 798239.937500,182355.265625
>> > 798428.625000,182096.046875 798459.437500,181919.343750
>> > 799039.500000,181669.687500 799844.437500,181778.218750
>> > 801606.000000,182278.328125 802187.500000,182349.484375
>> > 802352.250000,182269.375000 802645.437500,182260.484375
>> > 802723.437500,182336.953125 803011.375000,182404.953125
>> > 803051.937500,182195.703125 803435.562500,182110.609375
>> > 803918.750000,181764.390625 804157.062500,181805.593750
>> > 804800.812500,181292.812500 804995.312500,181000.812500
>> > 805246.625000,180951.531250
>> 805507.500000,180764.437500</gml:coordinates>
>> > </gml:LinearRing>
>> > </gml:outerBoundaryIs>
>> > </gml:Polygon>
>> > </MS_GEOMETRY>
>> > </g1gem>
>> > </gml:featureMember>
>> > _______________________________________________
>> > Mapserver-users mailing list Mapserver-users at lists.gis.umn.edu
>> > http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
>> http://lists.gis.umn.edu/mailman/listinfo/maps> erver-users
