[Mapserver-users] asymmetric lines
youssef chamoun
youssefchamoun at hotmail.com
Mon Feb 23 01:03:55 PST 2004
Hi Stephan,
I really appreciate your reply.
I tried the OFFSET -99 5 but mapserver gave an error and did not display any
image. I tried to look for the OFFSET word in the documantation but I could
find it only for the LABEL object. Can you please give me a more detailed
explanation?
Thank you again for your help
youssef
>From: "Stepan Kafka" <stepan.kafka at centrum.cz>
>To: "youssef chamoun"
><youssefchamoun at hotmail.com>,<mapserver-users at lists.gis.umn.edu>
>Subject: RE: [Mapserver-users] asymmetric lines
>Date: Mon, 23 Feb 2004 09:06:57 +0100
>Hi Youssef,
> you may use two approaches:
>1) offset lines. If you set OFFSET -99 <number> (eg -99 5) for line
>symbols,
>the result line is parallel to original one. Stacking symbols with multiple
>STYLEs you can achieve desired effect. (There is only simple (but quick)
>algorithm used for offseting, so there may be some problems with very
>tortuous lines)
>2) Truetype symbols. If you set GAP < 0 (eg. GAP -15), the symbols are
>oriented in "as digitized" orientation. Then you may set POSITION (UC, LC,
>UR, ..) to get different drawing effects.
>These functionality is available from 3.6.0 (?) version.
>Stepan Kafka
> > -----Pùvodní zpráva-----
> > Od: mapserver-users-admin at lists.gis.umn.edu
> > [mailto:mapserver-users-admin at lists.gis.umn.edu]za u¾ivatele youssef
> > chamoun
> > Odesláno: 20. února 2004 16:33
> > Komu: mapserver-users at lists.gis.umn.edu
> > Pøedmìt: [Mapserver-users] asymmetric lines
> > Hello,
> > can anyone please help me on a way to create asymmetric lines?
> > Thank you.
> > Youssef Chamoun
> > _________________________________________________________________
> > Protect your PC - get McAfee.com VirusScan Online
> > http://clinic.mcafee.com/clinic/ibuy/campaign.asp?cid=3963
> > Mapserver-users mailing list
> > Mapserver-users at lists.gis.umn.edu
> > http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
Add photos to your messages with MSN 8. Get 2 months FREE*.
http://join.msn.com/?page=features/featuredemail
More information about the MapServer-users
