[Mapserver-users] MAXSCALE MINSCALE
Ed McNierney
ed at topozone.com
Mon Feb 23 09:04:10 EST 2004
Daniel -
200 meters at what latitude and in which direction?
MINSCALE and MAXSCALE must of necessity refer to the UNITs of your map.
Since data in a "geographic" projection is in units of degrees, so must
the MINSCALE and MAXSCALE values. At 50 degrees North, for example, one
degree of longitude is only 65% the length of one degree of latitude, so
if you use a "geographic" projection where they're shown as equal, a
2,000-meters line running east-west will be displayed 50% longer than
the same line running north-south.
You need to convert your scale values to degrees and you should be fine.
- Ed
Ed McNierney
President and Chief Mapmaker
TopoZone.com
-----Original Message-----
From: Mills, Daniel [mailto:Mills_D at wrcplc.co.uk]
Sent: Monday, February 23, 2004 8:35 AM
To: 'mapserver-users at lists.gis.umn.edu'
Subject: [Mapserver-users] MAXSCALE MINSCALE
I am having real problems understanding the value required for this
layer parameter. All of my data is in lat/long. I wish some layers to
be turned off when the user has zoomed into appoax 2000 meters. Here is
a definition of my mapfile.
NAME "Europe in purple"
SIZE 600 400
PROJECTION
"proj=latlong"
"units=m"
END
STATUS ON
#SYMBOLSET /var/www/html/ms_teleco/symbols/symbols.sym
#SYMBOLSET "/var/www/html/maps/symbols/symbols.sym"
#EXTENT 424000 321200 424200 321400
EXTENT -23.27 66.34 -22.64 66.48
IMAGETYPE PNG
UNITS DD
#SHAPEPATH "D:/oracle/ora92/Apache/Apache/htdocs/maps/data/ccm"
WEB
IMAGEPATH "/var/www/html/maps/tmp/"
IMAGEURL "/maps/tmp/"
END
QUERYMAP
COLOR 255 255 255
SIZE 600 400
STATUS ON
STYLE HILITE
END
SCALEBAR
IMAGECOLOR 222 222 222
#IMAGECOLOR 172 202 236
LABEL
COLOR 0 0 0
SIZE SMALL
END #LABEL
SIZE 350 5
COLOR 255 255 255
BACKGROUNDCOLOR 0 0 0
OUTLINECOLOR 0 0 0
UNITS meters
INTERVALS 3
STATUS ON
END #SCALEBAR
LAYER
NAME "ccm catchments"
TYPE polygon
STATUS ON
TEMPLATE "../templates/catchments.html"
PROJECTION
"proj=latlong"
"units=m"
END
METADATA
ATTRIBUTES_VIEW "VWCATCHMENTS"
SPATIAL_VIEW "VWCATCHMENTS_SPATIAL"
END
# MINSCALE 2000
# MAXSCALE 400000
CONNECTIONTYPE oraclespatial
CONNECTION "******/**********@hern"
DATA "POLYGON FROM CMTPRD.CATCHMENTS"
# WHERE ROWNUM < 100)"
#DATA ccm_catchments
CLASS
COLOR 100 100 100
#colours the polygon outline
OUTLINECOLOR 0 0 0
SYMBOL 0
END
HEADER "../templates/catchments_header.html"
FOOTER "../templates/catchments_footer.html"
END
LAYER
NAME "ccm rivers"
TYPE LINE
STATUS ON
CONNECTION "*******/********@hern"
PROJECTION
"proj=latlong"
"units=m"
END
MAXSCALE 1540000
MINSCALE 2000
METADATA
ATTRIBUTES_VIEW "VWRIVERS"
SPATIAL_VIEW "VWRIVERS_SPATIAL"
END
DATA "DIRECTEDLINE FROM CMTPRD.RIVERSEGMENTS"
#DATA ccm_riversegments
CLASS
#STYLE
COLOR 255 255 255
OUTLINECOLOR 0 0 0
SYMBOL 0
#Name landlines
# COLOR 128 128 128
# OUTLINECOLOR 0 0 0
#END
END
END
END
Visit our websites www.wrcplc.co.uk, www.wrcnsf.com and www.nsf.org, as
well as www.waterportfolio.com for collaborative research projects.
The Information in this e-mail is confidential and is intended solely
for the addressee. Access to this e-mail by any other party is
unauthorised. If you are not the intended recipient, any disclosure,
copying, distribution or any action taken in reliance on information
contained in this e-mail is prohibited and maybe unlawful. When
addressed to WRc clients, any opinions or advice contained in this
e-mail are subject to the terms and conditions expressed in the
governing WRc client Agreement.
Mapserver-users mailing list
Mapserver-users at lists.gis.umn.edu
http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
