[Mapserver-users] Perl/Python/Ruby mapscript development documentation
Sean Gillies
sgillies at frii.com
Tue Feb 24 09:19:40 PST 2004
Following the example of the PHP-mapscript developers, we are now
maintaining
documentation for the development mapscript in a text file. In CVS in
can be
found at mapscript/doc/mapscript.txt. Language-specific appendices
will be
at mapscript/doc/python.txt etc. This new documentation fills the same
role as
the README file under mapscript/php3. Is a work in progress, but I'm
chipping
away at it every day and we'll be caught up with the current state of
the
development code soon.
We are trying out restructured text as a file format. It provides just
enough
structure that it can be parsed and rendered into XML or HTML. During
the
evaluation of mapscript.txt I will be regularly generating HTML from
the text source
and putting it up at
http://users.frii.com/sgillies/examples/mapscript.html
Links to the original text source and documentation about reST and
links to
download of reST tools are at the bottom of the page. If users
appreciate this
development documentation, I'll work the generation of HTML docs into
the mapserver
nightly build.
If you have considerations that you'd like to add to Bugzilla regarding
the
development docs, join the discussion here
http://mapserver.gis.umn.edu/bugs/show_bug.cgi?id=576
or discuss here on the list and I'll try to summarize on Bugzilla.
cheers,
Sean
Sean Gillies
sgillies at frii dot com
More information about the MapServer-users
