[Mapserver-users] Map Server compile problem
E Wright
eric.linux at shaw.ca
Tue Feb 24 14:19:57 EST 2004
This is a multi-part message in MIME format.
--Boundary_(ID_YD1NBIh3NjpLLLIOq9T/QA)
Content-type: text/plain; charset=ISO-8859-1; format=flowed
Content-transfer-encoding: 7BIT
Map Server compile problem.
Good evening, I am trying to install the MapServer using the following
configure:
./configure --with-gd=/usr/software/mapServer/gd-2.0.21
--with-tiff=/usr/software/mapServer/tiff-v3.6.1
--with-proj=/usr/software/mapServer/proj-4.4.7
--with-ogr=/usr/local/bin/gdal-config
--with-gdal=/usr/local/bin/gdal-config
--with-postgis=/usr/local/pgsql/include/pg_config --with-wfs
--with-curl=/usr/software/mapServer/curl-7.10.8/curl-config
This seems to run fine but when I try to run the make command I get the
following error:
gcc -c -O2 -Wall -DIGNORE_MISSING_DATA -DUSE_EPPL -DUSE_PROJ
-DUSE_PROJ_API_H -DUSE_WMS_SVR -DUSE_WFS_SVR -DUSE_TIFF -DUSE_JPEG
-DUSE_GD_PNG -DUSE_GD_JPEG -DUSE_GD_WBMP -DUSE_GD_FT -DUSE_OGR
-DUSE_GDAL -DUSE_POSTGIS -I/usr/software/mapServer/gd-2.0.21
-I/usr/software/mapServer/proj-4.4.7/src
-I/usr/software/mapServer/tiff-v3.6.1/libtiff -I/usr/local/include
-I/usr/local/include -I maptemplate.c -o maptemplate.o
gcc: no input files
make: *** [maptemplate.o] Error 1
I am fairly new to using Linux so I am not always too sure what
something is trying to tell me.
Any help that anyone can provide will be greatly appreciated.
Thank you in advance.
E Wright.
Content-type: message/rfc822; name="Map Server compile problem."
Date: Tue, 24 Feb 2004 02:24:31 +0000
Subject: Map Server compile problem.
To: mapserver-users at lists.gis.umn.edu
Message-id: <403AB5DF.5020906 at shaw.ca>
MIME-version: 1.0
X-Accept-Language: en-us, en
User-Agent: Mozilla/5.0 (X11; U; Linux i686; en-US; rv:1.6) Gecko/20040115
configure:
following error:
gcc: no input files
E Wright.
--Boundary_(ID_YD1NBIh3NjpLLLIOq9T/QA)--
