[Mapserver-users] Empty Map with Oracle spatial
Henrik Wilsdorf
H.Wilsdorf at gmx.net
Thu Feb 26 08:22:42 EST 2004
Hi, Mapserver-users!
I'm trying to get a map from Oracle Spatial 9i (9.2), but only the shape
layer
is visible in the image but no data (no polygon, no line, no point) from
oracle.
With the shape layers all works fine in different maps.
No other errors occure, but one in MS_ERRORFILE:
Thu Feb 26 12:26:40 2004 - msBuildPath: Unable to access file.
*** What does it mean???
This error comes also, when I get a correct map without oracle layers.
The Oracle connection is also o.k.
When I have an error in the tablename I get the following text:
msDrawMap(): Image handling error. Failed to draw layer named 'polygons'.
msOracleSpatialLayerWhichShapes(): OracleSpatial error. ORA-00942: Tabelle
oder View nicht vorhanden .
SQL statement: SELECT rownum, GEOMETRY FROM POLYGONS1
WHERE SDO_FILTER( POLYGONS1.GEOMETRY,
MDSYS.SDO_GEOMETRY(2003, NULL, NULL,MDSYS.SDO_ELEM_INFO_ARRAY(1,1003,3),
MDSYS.SDO_ORDINATE_ARRAY(-40,0,440,400) ),'querytype=window') = 'TRUE'
With the corrected statement I got tho following data back in SQLplus:
ROWNUM GEOMETRY(SDO_GTYPE, SDO_SRID, SDO_POINT(X, Y, Z), SDO_ELEM_INFO,
SDO_ORDINATES)
1 SDO_GEOMETRY(3003, NULL, NULL, SDO_ELEM_INFO_ARRAY(1, 1003, 1),
SDO_ORDINATE_ARRAY(50, 260, 0, 50, 90, 0, 120, 90, 0, 120, 260, 0, 50, 260, 0))
2 SDO_GEOMETRY(3003, NULL, NULL, SDO_ELEM_INFO_ARRAY(1, 1003, 1),
SDO_ORDINATE_ARRAY(140, 80, 0, 340, 80, 0, 340, 150, 0, 140, 80, 0))
This should be a rectangle and a triangle. Both are also shown in the Oracle
spatial advisor.
The spatial data are created with autodesk Map 2004.
I use Windows 2000 / IIS 5 and the binaries Mapserver 4.0.1 (PNG + Oracle)
from mapserver.gis.umn.edu.
The address I used in
IE6:
http://willi1/scripts/mapserv.exe?map=/data/projects/spatial1/testora1.map&mode=map
My Mapfile:
MAP
NAME "testora1"
STATUS ON
EXTENT 0 0 400 400
SIZE 600 500
SHAPEPATH "data"
SYMBOLSET "etc/symbols.sym"
FONTSET "etc/fonts.txt"
IMAGETYPE PNG
IMAGECOLOR 255 255 200
UNITS METERS
WEB
IMAGEPATH "/data/tmp/"
IMAGEURL "/tmp/"
LOG "/data/log/mslog.txt"
END
LAYER
NAME "polygonshape"
STATUS DEFAULT
DATA "polygonshape"
TYPE POLYGON
CLASS
STYLE
COLOR 200 200 100
OUTLINECOLOR 1 1 1
END
END
END
LAYER
NAME "polygons"
STATUS DEFAULT
DATA "GEOMETRY FROM POLYGONS"
TYPE POLYGON
CONNECTIONTYPE ORACLESPATIAL
CONNECTION "map1/abc at willi1"
CLASS
STYLE
COLOR 0 128 128
OUTLINECOLOR 1 1 1
END
END
END
LAYER
NAME "polylines"
STATUS DEFAULT
DATA "GEOMETRY FROM POLYLINES"
TYPE LINE
CLASS
STYLE
COLOR 0 0 255
SIZE 50
END
END
END
LAYER
NAME "points"
STATUS DEFAULT
DATA "GEOMETRY FROM POINTS"
TYPE POINT
CLASS
STYLE
SYMBOL 13
COLOR 1 1 1
SIZE 50
END
END
END
END
Waiting for some help.
Regards
Henrik Wilsdorf
GMX ProMail (250 MB Mailbox, 50 FreeSMS, Virenschutz, 2,99 EUR/Monat...)
jetzt 3 Monate GRATIS + 3x DER SPIEGEL +++ http://www.gmx.net/derspiegel +++
