[Mapserver-users] Empty Map with Oracle spatial
Fernando S.
simon at inf.univali.br
Thu Feb 26 09:54:14 EST 2004
This is a multi-part message in MIME format.
--------------040402050207060102060102
Content-Type: text/plain; charset=ISO-8859-1; format=flowed
Content-Transfer-Encoding: 8bit
Hi Henrik
I don't know if I can help you, but I will try.
Did you import the data to OracleSpatial from shapefile? If yes, did
you execute this command in sqlplus? (EXECUTE
SDO_MIGRATE.TO_CURRENT('TABLE','GEOMETRY_COLUMN');
If you execute your CGI passing layer=points, what it happens? Can
you see an image?
http://willi1/scripts/mapserv.exe?map=/data/projects/spatial1/testora1.map&mode=map&layers=points
Try to define one layer with status default and others with status
off , I don't know if import, just try.
Well, look the SDO_GTYPE in your databate. It's report type 3003.
Three-dimensional polygon, I don't know if mapserv show this type. Try
to pass this type to 2003 .
Fernando Simon - simon at cttmar.univali.br
DataBase Manager, Mapserver, OracleSpatial and PostGis Developer
G10 - Laboratório de Computação Aplicada
Fone: 047 - 341 7960
http://g10.cttmar.univali.br
Henrik Wilsdorf wrote:
>Hi, Mapserver-users!
>I'm trying to get a map from Oracle Spatial 9i (9.2), but only the shape
>layer
>is visible in the image but no data (no polygon, no line, no point) from
>oracle.
>With the shape layers all works fine in different maps.
>No other errors occure, but one in MS_ERRORFILE:
> Thu Feb 26 12:26:40 2004 - msBuildPath: Unable to access file.
>*** What does it mean???
> This error comes also, when I get a correct map without oracle layers.
>The Oracle connection is also o.k.
>When I have an error in the tablename I get the following text:
>msDrawMap(): Image handling error. Failed to draw layer named 'polygons'.
>msOracleSpatialLayerWhichShapes(): OracleSpatial error. ORA-00942: Tabelle
>oder View nicht vorhanden .
>SQL statement: SELECT rownum, GEOMETRY FROM POLYGONS1
>WHERE SDO_FILTER( POLYGONS1.GEOMETRY,
>MDSYS.SDO_GEOMETRY(2003, NULL, NULL,MDSYS.SDO_ELEM_INFO_ARRAY(1,1003,3),
>MDSYS.SDO_ORDINATE_ARRAY(-40,0,440,400) ),'querytype=window') = 'TRUE'
>With the corrected statement I got tho following data back in SQLplus:
>ROWNUM GEOMETRY(SDO_GTYPE, SDO_SRID, SDO_POINT(X, Y, Z), SDO_ELEM_INFO,
>SDO_ORDINATES)
> 1 SDO_GEOMETRY(3003, NULL, NULL, SDO_ELEM_INFO_ARRAY(1, 1003, 1),
>SDO_ORDINATE_ARRAY(50, 260, 0, 50, 90, 0, 120, 90, 0, 120, 260, 0, 50, 260, 0))
> 2 SDO_GEOMETRY(3003, NULL, NULL, SDO_ELEM_INFO_ARRAY(1, 1003, 1),
>SDO_ORDINATE_ARRAY(140, 80, 0, 340, 80, 0, 340, 150, 0, 140, 80, 0))
>This should be a rectangle and a triangle. Both are also shown in the Oracle
>spatial advisor.
>The spatial data are created with autodesk Map 2004.
>I use Windows 2000 / IIS 5 and the binaries Mapserver 4.0.1 (PNG + Oracle)
>from mapserver.gis.umn.edu.
>The address I used in
>IE6:
>My Mapfile:
>MAP
> NAME "testora1"
> STATUS ON
> EXTENT 0 0 400 400
> SIZE 600 500
> SHAPEPATH "data"
> SYMBOLSET "etc/symbols.sym"
> FONTSET "etc/fonts.txt"
> IMAGETYPE PNG
> IMAGECOLOR 255 255 200
> UNITS METERS
> WEB
> IMAGEPATH "/data/tmp/"
> IMAGEURL "/tmp/"
> LOG "/data/log/mslog.txt"
> END
> LAYER
> NAME "polygonshape"
> STATUS DEFAULT
> DATA "polygonshape"
> TYPE POLYGON
> CLASS
> STYLE
> COLOR 200 200 100
> OUTLINECOLOR 1 1 1
> END
> END
> END
> LAYER
> NAME "polygons"
> STATUS DEFAULT
> DATA "GEOMETRY FROM POLYGONS"
> TYPE POLYGON
> CONNECTIONTYPE ORACLESPATIAL
> CONNECTION "map1/abc at willi1"
> CLASS
> STYLE
> COLOR 0 128 128
> OUTLINECOLOR 1 1 1
> END
> END
> END
> LAYER
> NAME "polylines"
> STATUS DEFAULT
> DATA "GEOMETRY FROM POLYLINES"
> TYPE LINE
> CLASS
> STYLE
> COLOR 0 0 255
> SIZE 50
> END
> END
> END
> LAYER
> NAME "points"
> STATUS DEFAULT
> DATA "GEOMETRY FROM POINTS"
> TYPE POINT
> CLASS
> STYLE
> SYMBOL 13
> COLOR 1 1 1
> SIZE 50
> END
> END
> END
>END
>Waiting for some help.
>Regards
>Henrik Wilsdorf
Content-Type: text/html; charset=us-ascii
Content-Transfer-Encoding: 7bit
<!DOCTYPE html PUBLIC "-//W3C//DTD HTML 4.01 Transitional//EN">
<html>
<head>
<meta content="text/html;charset=ISO-8859-1" http-equiv="Content-Type">
<title></title>
</head>
<body>
<font face="Helvetica, Arial, sans-serif">Hi Henrik<br>
I don't know if I can help you, but I will try.<br>
did you execute this command in sqlplus? (EXECUTE
SDO_MIGRATE.TO_CURRENT('TABLE','GEOMETRY_COLUMN');<br>
you see an image?<br>
<a class="moz-txt-link-freetext" href="http://willi1/scripts/mapserv.exe?map=/data/projects/spatial1/testora1.map&mode=map&layers=points">http://willi1/scripts/mapserv.exe?map=/data/projects/spatial1/testora1.map&mode=map&layers=points</a><br>
off , I don't know if import, just try.<br>
to pass this type to 2003 .<br>
<br>
<br>
Fernando Simon - <a class="moz-txt-link-abbreviated"
href="mailto:simon at cttmar.univali.br">simon at cttmar.univali.br</a> <br>
<br>
<br>
<br>
<br>
<a class="moz-txt-link-freetext" href="http://g10.cttmar.univali.br">http://g10.cttmar.univali.br</a><br>
==================================================================</font>
<br>
<br>
<blockquote cite="mid12090.1077801762 at www38.gmx.net" type="cite">
<pre wrap="">Hi, Mapserver-users!
layer
oracle.
SDO_ORDINATES)
spatial advisor.
IE6:
<a class="moz-txt-link-freetext" href="http://willi1/scripts/mapserv.exe?map=/data/projects/spatial1/testora1.map&mode=map">http://willi1/scripts/mapserv.exe?map=/data/projects/spatial1/testora1.map&mode=map</a>
My Mapfile:
MAP
NAME "testora1"
STATUS ON
EXTENT 0 0 400 400
SIZE 600 500
SHAPEPATH "data"
IMAGETYPE PNG
UNITS METERS
WEB
IMAGEURL "/tmp/"
END
LAYER
NAME "polygonshape"
STATUS DEFAULT
DATA "polygonshape"
TYPE POLYGON
CLASS
STYLE
COLOR 200 200 100
OUTLINECOLOR 1 1 1
END
END
END
LAYER
NAME "polygons"
STATUS DEFAULT
TYPE POLYGON
CLASS
STYLE
COLOR 0 128 128
OUTLINECOLOR 1 1 1
END
END
END
LAYER
NAME "polylines"
STATUS DEFAULT
TYPE LINE
CLASS
STYLE
COLOR 0 0 255
SIZE 50
END
END
END
LAYER
NAME "points"
STATUS DEFAULT
TYPE POINT
CLASS
STYLE
SYMBOL 13
COLOR 1 1 1
SIZE 50
END
END
END
END
Regards
Henrik Wilsdorf
</pre>
</blockquote>
<br>
</body>
</html>
--------------040402050207060102060102--
