[Mapserver-users] altering $layer->{symbolscale} before draw()
Nikolai Vladychevski
niko at isl.net.mx
Fri Feb 27 10:05:10 EST 2004
I have a perl script that uses mapscript to create a map with many layers. I
want to dynamicaly alter SYMBOLSCALE of the layer depending on the scale of
the map, because when user zooms too much, the symbol is too big. I can not
lower SYMBOLSCALE and leave it fixed in mapfile becasue when user is
browsing at high scales, the symbols is very small, almost invisible.
So I have this code, but it isn't giving expected results, nothing happends:
sub drawLayers {
my $m=shift; #map
my $i=shift; #image
for ($lidx=0;$lidx<$m->{numlayers};$lidx++) {
$l=$m->getLayer($lidx);
if ($m->{scale}<32000 && ($l->{name} eq "emplazamientos")) {
$l->{symbolscale}=320; #<- this doesn't make any difference
$l->draw($m,$i);
here are some lines in mapfile:
LAYER
NAME emplazamientos
DATA emplazamientos.shp
CLASSITEM 'ID'
LABELITEM 'ID'
SYMBOLSCALE 32000
CLASS
NAME 'emplazamientosactivos'
COLOR 0 0 255
SYMBOL 'emplazamiento'
SIZE 10
TEMPLATE "emplazamiento.html"
END
SYMBOL
NAME "emplazamiento"
TYPE TRUETYPE
FONT transmision
FILLED true
ANTIALIAS true
CHARACTER "F"
END
How do I have to change the {symbolscale} variable in order to achieve
changes in the display, as I do it above, setting it to different values
Thanks in advance
Nikolai
